LACIE NAS storage drive
Wed, Dec 31 2008, 12:24AM
Hi was looking for a drive for use with the sonos set up saw a 1tb lacie drive for £140 looks good but anyone had experience of these? is it as simple as connecting the two via ethernet cable. Thanks
Wed, Dec 31 2008, 1:08AM
#2
Hi thats the one i saw it for £140 delivered for 1tb which seems incredibly cheap and it looks pretty nice from the photos well considering its a hard drive! Ive got a Bt home hub so will use that. Might be the one to go for then thanks for that!
Wed, Dec 31 2008, 1:13AM
#3
- Login to post comments
Do you mean the Neil Poulton, black Lacie drive? If so I have just bought one to increase the capacity on my Thecus. Seems like a cracking little drive, very quiet compared to Lacie drives I've had in the past. I don't have a Sonos though it should work if you leave it in SMB. You will need to attach the NAS to a router though, it's not as simple as plugging it straight in.
