Is EQ'd playback on Mac into Naim bit perfect?
7 replies [Last post]
audiokid
audiokid's picture
I play FLAC files using Fidelia software, on my Mac mini, via optical into my Naim Supernait.
I have occasionally used the EQ and wondered if this degrades the SQ? Is it bit perfect if I don't play with the EQ (effectively data sent to the DAC) and becomes a 'non bit perfect' Mac played track when it is manipulated with the EQ?
Sorry if it's a daft question!
6th.replicant
6th.replicant's picture
RE: Is EQ'd playback on Mac into Naim bit perfect?
IIRC, a Mac using iTunes is bit-perfect.
However, if you include the likes of Fidelia or Amarra etc in the mix, then I'm not certain  puzzled
John Duncan
John Duncan's picture
If it's EQd you've played with the original signal, so it isn't bit perfect, no.
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
quadpatch
quadpatch's picture
Am I right in assuming that iTunes on a PC is not bit perfect? Because there is no way to select WASAPI or ASIO or Kernal Streaming as far as I can see... ru.. *cough* ..bbish.
__________________
PC>JRiver> DAC/amps: FiioAudinstYulongArcamFostex, Audiolab, SchiitOppoIfi ●
Headphones: D7000Q701M80M100, DT770, DT880HP100HP200Mad Dog, HD650 ●
Paul.
Paul.'s picture
Nope you can't, and yes it is.  If you must use iTunes on a PC then you can use the multi-plugin to alow iTunes to fob off the processing to fubar (and do the wasapi thing).  That way you can use iTunes organisation, tagging, syncing but not audio processing.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
shooter
shooter's picture
Like John say's it's not bit perfect, only unaltered signal will be.
What matters most is your musical enjoyment, i use EQ and couldn't be without it. Smile
SteveR750
SteveR750's picture
Bit perfect simply means the data is completely unchanged compared to the source. EQ alters it, just as windows re-sampling does.
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
MajorFubar
MajorFubar's picture
Ignoring the 'bit perfect' part, whether or not EQ degrades the sound depends on your definition of 'degrade'.  It degrades it in so far as what you're listening to is not an analogous representation of the original audio file, because you've adjusted the tonal balance.  But if that makes a particular track/type of music more enjoyable for you, then it's hard to argue that the sound has been degraded.  Same thing goes for any tone controls, including the once-ubiquitous Loudness button.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
