Help me to convert DVD audio into flac...
Tue, Nov 25 2008, 8:15PM
Pretty much as the title says, I'm using a Vista PC.
I just need to know what programs are best/easiest to help me create 24/96 flac files from DVD-A.
Thank you in advance for your help.
I found DVDPean after a quick google of "dvd audio flac", I'm sure there are others - don't know if EAC will do it, for example.
CA StreamMagic 6 | CA 751BD | CA 651A | PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
