Further Airport Express woes - playback problems
40 replies [Last post]
PJ1200
PJ1200's picture
Online
I have done a search on the net, and can't really find anything concreate. There are a few 'experts' on here, so thought I would tap into their knowledge!!
I have finally sorted out my airport express, and set it up in client mode to be attached to my O2 broadband router, which is downstairs. The light is green and it finds the network ok, and plays music.
Problem is, after every minute or so the music cuts out for a second or two!?? WHY!?!!?
I'm getting rather annoyed with this now. Surely a product that's MAIN feature is to wirelessly transmit music should do just that!! Mine doesn't!
The AX is set up as a client through my O2 router, and this maybe the problem? I note that although the signal strength is 'Excellent' it is only broadcasting at 11MPS? My old netgear used to be at the full 54MPS. Would this be a problem? I don't want it to be as the thought of trying to set up my netgear to run firstly on O2 broadband and then to set up my AX to run through the netgear fills me with huge amounts of anger!
Please help!!
NB, I do have the 'robustness' selected on the Admin Utility, makes no difference!
__________________
HiFi: Sony TA-FB940R Integrated Amp, Sony CDP-XB930 CD player, Acoustic Energy Aegis, Apple Airport Express (V2). Sonos Play 3 and Bridge
AV: Denon AVR-2310, KEF 3005, Sky HD, Apple TV2, Panasonic BD Player.
TV: Panasonic TX-P50GT50
John Duncan
John Duncan's picture
Re: Further Airport Express woes - playback problems
Do you have any other wireless devices on the network that may be 802.11b instead of 802.11g? This will make the router run at 'b' speeds (11 mbps). If not, set the router to only use 'g' instead of mixed 'b' and 'g'. In fact, you might even find that it's set to 'b' anyway - this isn't something you'd notice if you were just using it for internet connection.
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
PJ1200
PJ1200's picture
Online
Hmm - no other devices on the network, so will check the O2 router settings tonight... not sure how to, but can't be that difficult. The internet speed is a little on the slow side and has recently dropped a couple of times, so could be the reason - the o2 router is on 'b'!!
Hopefully this is easy to do.... I'll have a search on the net.
Thanks John
__________________
chebby
chebby's picture
Play with using different channels on the wireless router until you find one that gives consistent and high rate.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
PJ1200
PJ1200's picture
Online
I'll also try that too. I have a Netgear adapter, which seems to select random channels, but again, I'm sure I'll be able to select one.
__________________
John Duncan
As in the adapter on the PC? Should be configurable, along with the BT Hub - you ought to be able to enter its configuration screen by going to http://bthomehub.home/ in your browser.
__________________
PJ1200
PJ1200's picture
Online
Network adaptor is Netgear, as I do also have a Netgear router that I used to use. I switched to O2 and they sent a separate router. So I have the netgear adapter still and use that with the O2 router. I'll go to the O2 settings to check the wireless is set up on g, rather than b. I'll also check to see if I can manually change the channel.
Will keep you posted...
__________________
PJ1200
PJ1200's picture
Online
Further update...
I attempted to change the wireless protocol last night on my router to just 'g' instead of 'b & g'. This caused massive failure!! The wireless adapter would not connect to the router!?
Ended up on the phone to O2 support, who reset the router.
Long story, but they got it back up and running, and commented that our connection was dropping about 600 times a day!!! This explains why our internet connection recently has been very temperamental.
They've done a fix there end and it's meant we've had to use the phone point under the stairs (the master point) which is massively inconvenient, but I'm sure we'll work around it.
I was hoping that this maybe the reason why the AX keeps dropping? It's a client for the router and if the router is dropping connection would this have an effect on playback??
__________________
chebby
chebby's picture
Can you get Virgin Media cable in your area?
We have had cable for 17 months now and we have only experienced one 3 hour outage (Virgin name server got overloaded) in that entire period.
__________________
John Duncan
Can't comment on whether the router dropping its connection is causing the network problems, but certainly seems plausible. My bigger concern would be the fact that your wireless adapter won't work with 'g' only - are you sure it's a) a 'g' adapter (I think you said it was) and b) is configured to work with 'g'?
__________________
PJ1200
PJ1200's picture
Online
Can't get Virgin in my area - otherwise I'd snap it up!
The adapter is, I'm almost certain, a 'g' adapter. The router was obviously ok when I changed the settings, as it came up on the 'wireless network', but the adapter just couldn't connect to it... so maybe that was why it didn't work???
I don't know. The router has been sorted (I imagine back to both 'b' and 'g' setup, and I will try the AX again, hoping that the dropping of the connection had interferred with the playback.
__________________
PJ1200
PJ1200's picture
Online
This is starting to really get my back up!
Wireless router is definitely a 'g' router. I updated the latest firmware on it at the weekend, but still no joy.
The internet is working fine, and is apparently obtaining full 8MB speed, which is good.
However, AX is still dropping on playback every minute. I have even updated to the latest iTunes (8.0.2 I think), but still has not fixed it. I've been on the Apple website and posted a thread to see if anyone has any ideas over there. A quick search suggests people think iTunes 8 could be to blame, although there is not solid proof of this.
Spoke to O2 again at the weekend. The guy there was most helpful. Because the internet is working perfectly they are quite within their rights to tell me to sort it out myself (as it's an Apple product). He spent all morning with me looking into it, and has promised to call me this week to update me if he's come up with anything else.
In stark contrast, I rang Apple who were about as helpful as chocolate teapot! Even tried to sell me a brand new AX on the basis my current one was old!!
Apple really get on my nerves at the moment!
All I want to do is listen to music on my hifi without any gaps! That's what the AX is supposed to do (primarily) and it FAILS completely!
NB I've also played with the buffer settings in iTunes preferences - changed to 'Large' from 'Medium'. No joy.
__________________
John Duncan
There's a list of things to try here.....
__________________
John Duncan
Furthermore, yes the router is 'g', but is the adapter? 8 meg internet tells you nothing, since a 'b' wireless network would be 11 (though obviously this should still cover music streaming).
__________________
PJ1200
PJ1200's picture
Online
John - firstly, thanks for taking the time to help. Much appreciated.
I've actually seen that web page you've posted (saw it on Sat morning)! It hasn't been able to shed any light on mine.
The Netgear adapter is definitely 'g'. http://www.netgear.co.uk/wireless_networkadaptor_wg111.php
Agree with the 11mbs issue. Although I get confused with Mega bits per second and Mega bites!? Can wireless routers/adapters stream 8 mega bites? Sorry if that all seems stupid!
I can't believe this is such a hassle!?
My next idea is to have the AX as a base station, and manually disconnect from my O2 router and connect to the AX when I want to play music, but that is hardly ideal is it!?
__________________
John Duncan
Networks are described in terms of bits, storage in bytes (generalising) so an 8 meg internet connection is 8 megabits per second, an 8 meg file is generally 8 megabytes (ie 8 times bigger).
Most wired networks run at 100 megabits per second (though gigabit ethernet is becoming more common) and are therefore twice the speed of your average 'g' network (though 'g+' runs faster, and 'n' faster still), but music streaming is usually no more than 1411kbps = 1.4 megabits per ssecond, so your network should have no problem.
And no, you shouldn't have to do any connecting or disconneting, the damned thing should just work, agreed. What's the spec of PC running iTunes?
__________________
