Foobar 1 Beta released
Tue, Nov 24 2009, 7:51PM
Foobar 1 Beta released a couple of days ago, If you are up for trying it make sure you backup your config file so you can go back to your current version. Cronflow shows included for legacy purposes and any changes will take effect immediately, Prettypopup works but the change panel is greyed out. I backed out for present but will load again when I have time available to check it's all working fine with my setup/config.
