Difference in digital sources
128 replies [Last post]
demartin_1
demartin_1's picture
Hello there,
 Just a quick theoretical question for you all based on the following set ups:
  • Music is ripped to a hard drive
  • Music accessed through a music server
  • Music server outputs to a DAC
  • DAC outputs to an amplifier
Does it make any difference what music server is used in this example? To put it another way would a sonos / squeezebox / linn ds all sound the same?
For the purpose of control assume that the hard drive, dac and amplifier are held constant.
I'm interested only in sound quality, not the ease of use of each server.
My hypothesis is that there is no difference between any music server in this scenario.
 Thank you.
amcluesent
amcluesent's picture
Re: Difference in digital sources
>My hypothesis is that there is no difference between any music server in this scenario.<
 There will be differences in the jitter on the S/PDIF even if you turn off any upsampling in the Linn.
__________________
Stello CDT200, Squeezebox Transporter, Myryad MT100, Audio Analogue Maestro Settanta REV2.0, Sonus Faber Guarneri Homage  · Squeezebox Touch, Quad FM4\34\306, Sonus Faber Concertinos · Squeezebox Controller
manicm
manicm's picture
By all accounts the Linn DS sounds best, and is also the most expensive.
__________________
Arcam Solo Mini/Monitor Audio RX1/Cambridge Audio 751BD/Samsung 37” LCD
demartin_1
Why would that be?
 Don't they all just output the same digital signal to the DAC?
manicm
manicm's picture
demartin_1:
Why would that be?
A large part of the DS's sound is its internal DAC, and interface which is designed for minimum jitter. Another reason perhaps is because it's a wired solution, unlike Sonos or Squeezebox.
__________________
nads
nads's picture
manicm:
demartin_1:
Why would that be?
Yes but that is not what is being asked.
I have never tried what the OP is sujesting but i can not see why it would sound any different.
__________________
Not a HiFi Nut. Just has a pile of Nads.
manicm
manicm's picture
nads:
manicm:
demartin_1:
Why would that be?
Well actually I forgot one very, very important point - Linn DS is the only digital player that will natively play up to 24b/192k files, the Sonos and Squeezy simply don't handle this - even though their internal DACs might.
It's akin to DVD upsampling and full HD Blu-ray, or playing Blu-Ray on a 'HD Ready' TV instead of full HD.
That is a massive advantage of the Linn DS if one can afford it and willing to sit through the initial painful setup.
And a lot of tweaking is needed to get higher resolution files to play properly off a PC.
To answer your and the OP's question, I'll answer that with another question - why do some CD players sound better than others?
__________________
Andrew Everard
Andrew Everard's picture
demartin_1:
Well, given that music can sound different when exactly the same file is stored on, and streamed from, different brands/types of USB keys...
I think your hippopotamus may be somewhat wide of the mark.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
The_Lhc
The_Lhc's picture
manicm:
Sonos is part wired, the first zone must be cabled to the router, Sonos don't support any other configuration. All zones can be cabled if you want.
__________________
No signature worth mentioning...
Alec
Alec's picture
Andrew Everard:
demartin_1:
Never heard that before. Interesting.
__________________
Formerly known as al7478...
HC: Panasonic PXP 42 V20; Panasonic DMP BD35; Humax Foxsat-HDR
Music: Optical out from Asus P7H55-M Motherboard into AVI ADM 9.1 speakers.
"Music will provide the light you cannot resist"
storsvante
storsvante's picture
al7478:
Andrew Everard:
demartin_1:
I'm sorry, but this is nonsense and just one step too far. Andrew, if you can demonstrate audible differences (by blind testing) on identical source material stored and sourced from different brands of USB sticks I swear I will eat not only my socks but also the USB sticks that you were comparing.
In the meanwhile I will consider upgrading my keyboard cable so that I can ensure there is enough headroom to deliver this post to your web site without any loss of clarity, sharpness or definition of the characters I'm entering.
smmee
smmee's picture
well storvante no respond from Andrew, perhaps if you also offered to eat that new keyboard of yours he would take up your challange.
Alec
Alec's picture
storsvante, you could always try it.
__________________
demartin_1
Thank you all for your contributions. Although I am none the wiser I am now going to pay a lot more attention to my hippopotamus.
If it is true that different hard drives / usb sticks etc really do sound different then I can see this hard drive based music business getting really expensive.  I can also see my friends putting me in the nut house, they used to think I was crazy enough when I spent a weekend playing with a box of cables from my local hi fi shop.
one off
one off's picture
dont worry they dont make a difference another myth
Andrew Everard
I was as surprised as some posters here seem to be, but it does make a difference. Best explanation seems to be that different sticks deliver data at different speeds.
__________________
