Crackles between tracks on Airfoil
Sat, Oct 16 2010, 1:52PM
Hi there
I'm running WinXP using Airfoil to stream Spotify from my laptop to Airport Express which is connected to my hifi.
When I change track on Spotify my laptop makes a couple of clicks, then for the first few seconds the volume is a lot quieter and there are crackles and clicks coming through the hifi speakers. After that it plays absolutely fine. Any idea what the issue is? If I do similar in iTunes (and hence don't use Airfoil) I have no such problem.
Any advice appreciated as apart from that I'm really happy with the setup!
many thanks
Gareth
