Bowers and Wilkins mm1 or bang and olufsen beolab 4 computer speakers
18 replies [Last post]
Daniel 1
Daniel 1's picture
I can't make up my mind what ones to get any idears would be great!!!
chebby
chebby's picture
Re: Bowers and Wilkins mm1 or bang and olufsen beolab 4 computer
The B&W MM1s were superb when I heard them at Audio-T earlier in the year.
I have heard the B&O Beolab 4s (excellent too) but seem to remember they cost about 2.5 times more than the MM1s. (I have not tried the Beolab 4 PC versions.)
If I were well-off and had room-decor that benefitted from B&Os extra styling flourish then I would get them.
The MM1s are good up to about 4 feet away but are definitely computer speakers and won't fill a room.
Don't forget Genelec 6010a at around £350 a pair. (Watch out though, the sort of shops that sell them often show price per speaker rather than per pair.) Personally I could not bear to look at Genelecs for too long. YMMV
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Daniel 1
Daniel 1's picture
I've heard the beolab 4 pc they sounded great cost £650.00 thought they lacked bass but could be wrong as the music wearnt exactly the bass type. They definelty filled a room and more, but at the end of the day I'm not looking 4 room filling, but computer speakers! You could say the beolab 4 pc are more a main stereo than computer speakers.
Grottyash
Grottyash's picture
That's a good price for the B&O speakers.
I heard the MM1s recently with the intention of buying them, but in the end decided not to.
The bass, as you'd expect for the size, was less than convincing, but it was the slightly hollow nature of the sound that put me off.
Genelec are also a good idea, if you like their idiosyncratic looks.
manicm
manicm's picture
Grottyash:
I have the MM1s on my desk and they are anything but 'hollow' sounding. Where did you hear them? One also needs to take heed that you need to depress the slave speaker cable completely with a *bit* of force in the middle so it does not stand loose - this makes a BIG difference - so much so that I removed the blu-tac before I realised this.
Now I previously had a 2,1 system for my PC, and with the MM1s you have to initially accept that there is no subwoofer. After accepting this and acclimitasing to the sound after a few days you'll realise the MM1 has excellent bass for its size - whatever music I play, whatever games I play.
I'll admit they are pricey, but needing a subwoofer is a big plus for me - I don't have to worry about stretching my feet and damaging something.
__________________
Arcam Solo Mini/Monitor Audio RX1/Cambridge Audio 751BD/Samsung 37” LCD
shooter
shooter's picture
I didn't have a great experience with the MM1's back in the summer, i found the bass undefined and wooly; applying some downward pressure with the hand helped but not ideal and Blu-Tack never helped either. A positive from them purely on a musical front was the treble, nice and detailed but never harsh. These desktop PC speakers are never going to give low end frequencies how we're used to them but the MM1's didn't do it well and when the volume got higher the sound got worse. After a day at home with them they went back to Apple and got a refund and i'm still without PC speakers today.
The B&O look nice and i like that you can get them off the desk and mount them on the wall/ceiling or stands and could be worth a demo at your nearest B&O centre, again though limited low end frequencies and looking at the B&O site no "PC" sub woofer on offer.
The one desk top system i looked at and could be worth putting in the mix is Eclipse's TD307PAII. Nice looking speaker's with own amplification and an output for "PC" sub if required. And like the B&O wall and stand mountable. Stockists all over the UK for demo.
manicm
manicm's picture
Shooter, your experience is the complete opposite of mine - I cannot emphasise this enough - it is not clear in the manual, but is a tip on the B&W site - on the slave speaker you have to depress the cable *right* in with force to make it stable. Until you do this yes the bass is weak.
My experience was similar to yours - until I did the above and removed the blu-tac. The bass is very well defined now, and it's just amazing with games when you realise there's no sub.
__________________
johnnymunro
johnnymunro's picture
I watch this thread with interest because I'm in the same position as you Daniel 1 .
I did go for a test of the mm1's and my initial impressions were good. I then hovever had a listen to a zeppelin dock straight after and the there was no comparison with the soundstage. I understand that these two items share similar technology but I left realising that the mm1's although sounding good did not provide the bass I prefer to fill a room for the imac.
Back to the drawing board.
Daniel 1
Daniel 1's picture
Apart from the inputs are hard to push in to the main speaker, and that the wire on the slave speaker got to be pushed down in order for the speaker to be stable is there any real problems with it? What this I heard about blu tack?
manicm
manicm's picture
johnnymunro - Indeed the MM1s are *desktop* speakers and are not meant to fill the role of normal speakers or large docks like the Zeppelin. Their amp is only 18w in fact.
Daniel 1 - it's no issue at all - at the bottom of the slave speaker depress - i.e. bend the cable at the centre with some force so it stays at the bottom, ensuring the speaker is stable. The master speaker i.e. the one with the amplification is fine out of the box.
__________________
chebby
chebby's picture
manicm:
I agree that the MM1s are desktop speakers but their power is 18 watts x 4 (18watts to each driver) and not... "only 18w"
__________________
Daniel 1
Daniel 1's picture
Then my search is over these speakers sound to me that they are the best for the job as far as desktop speakers go! Which they are made for in the first place if you want a main system then buy a main system and not desktop speakers. As for the bass same again it's not huge on bass but it gives you what you need for desktop speakers. I found the bang and olufsen beolab 4 pc more main stereo than desktop speakers some one said about you can put then on floor stands? But surely that beats the point of having desktop speakers!! Plus I found the beolab 4 pc more acoustics/for classical music so there not good all rounders anyway. Done and dusted
shooter
shooter's picture
manicm:
I didn't have a problem with the slave just the sound of the MM1. The issue for me was the bass and with the MM1's sitting on the dest and being lightweight didn't help matters. My desk is wood but if you have a desk that doesn't resonate as much could help
With the "desktop" speaker being what it is isolation would be a fair call and either mounting on the wall immediately behind the desk (if possible) or putting them on stands wouldn't be too "far out". If either done the job well; then it's an option to explore.
idc
idc's picture
Does the MM1 have a DAC in it? I have been reading up and see they can be connected to your PC with a USB, but there is no mention of a DAC. Also, can they be mounted on a wall?
__________________
Internet - laptop - DAC - amp - lots of headphones.
http://idc1966.blogspot.co.uk/
"A music lover will stop what he's doing and stay glued to a favorite piece of music even if it's coming over a 3" speaker or a public-address system..." - Ken Rockwell
Grottyash
Grottyash's picture
See here: http://www.bowers-wilkins.com/Downloads/Product/Brochure/ENG_FP29793_MM-1_brochure.pdf.
But no, it doesn't.
idc
idc's picture
Thanks, in the brochure it states
USB Connections
If you wish to listen to audio either stored or streamed on your PC/Mac, connect from a spare USB socket on the computer to the USB socket on the underside of the powered speaker. Use the USB cable supplied.
So how does that work?
__________________
