BitPerfect is...erm...perfect!
35 replies [Last post]
MajorFubar
MajorFubar's picture
I saw this app in one or two signatures round here so I thought I'd give it a go.
I use iTunes to listen to ALAC rips from my favourite CDs through my HRT Streamer II+
First album I tried is the first album I always head to when I've upgraded a piece of HiFi: China by Vangelis.
Wow. Shock  That's really the only word which covers it.
Someone's just widened the space between my speakers by three feet and knocked-out the back wall.
How the heck does it do this???
Furthermore - and here's a bit of a gripe I guess - why doesn't iTunes sound THIS GOOD out of the box??!
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
Dan Turner
Dan Turner's picture
RE: BitPerfect is...erm...perfect!
And why doesn't iTunes automatically switch sample rates? Fortunately another thing that Bitperfect takes care of! It's good isn't it?
__________________
Sonos ZP90 / CA 751BD / Sky HD / Apple TV
-> AVI ADM40
-> Panasonic PDP50G10
6th.replicant
6th.replicant's picture
Does BitPerfect require much setup faffage and geek skills?
I've tried similar iTunes upgrades/bolt-ons in demo form, such as Amarra, Pure Music et al, and lost patience with the required myriad re-sets/re-boots etc. (Although will admit I've the attention-span of a crack-addicted squirrel.)
Dan Turner
It requires no setup. You install it, launch it, and it just sits in the background doing its thing whilst you use iTunes, or another media player, just like you normally would. There are some preferences, but it's configured fine for most users straight 'out of the box'.
__________________
-> AVI ADM40
chebby
chebby's picture
Online
How about gapless playback and other settings?  I have a lot of gapless material (especially dramas) where I can't afford to have software messing it up.
I have already ripped all of my CDs with error correction switched on. How can it improve on that?
How does this software work? Does  it get into the inner workings of iTunes or just sit 'outside' it and improve the digital signal coming from iTunes?
Is it competent?
I would like to read about the problems as well as the praise before I try it.
Thanks.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
SteveD
SteveD's picture
Hi Chebby, it does support gapless playback and is very competent, it's basically iTunes in every sense and is as straightforward as it gets. It just sits alongside iTunes correcting the shortfalls of it (such as automatically switching between high resolution and normal resolution and cutting out the computer's processing) seamlessly.  I've used JRiver which was also good but only works on Windows and had some issues with errors occurring in playback and did not support protected AAC format.  I then bought a Mac (which you can't use JRiver on) so bought BitPerfect.
JRiver is about £40 or so I recall and BitPerfect around £6 or £7.
BitPerfect was very easy to install and has a good straight forward guide on how to set up for optimal performance on your system (5 mins max.) or you can run it in default mode which will still be bit perfect.
The iTunes interface is completely unaltered and the BitPerfect settings once established at the start don't need changing at all but if you want to access it or disable it etc the icon just sits in the menu bar at the top of your screen.  If you like the iTunes interface and have a Mac it does make a positive difference by correcting the auto-switching between high and normal res. so although you may not notice any audible improvement in sound by enabling an unaltered processing of the audio - for the money it is still a no-brainer in my view.
__________________
MacBook Air (iTunes/BitPerfect) > Chord Company USB Silver Plus > MF V-Link II > Chord Optichord > Rega DAC > Tellerium Black I/C > Rega Brio-R > Tellerium Black S/C > Rega RS3s
iTouch > Graham Slee Novo > Grado SR80is
MajorFubar
Hi Chebby, ^^^WHS, really.  I haven't noticed any issues re gapless playback on my system running Lion and iTunes 10.6.1. I doubt you would do either.  There are a few configurable parameters, with recommendations for their settings explained here: http://bitperfectsound.blogspot.co.uk/p/manual.html.  But tbh it worked absolutely fine 'out of the box'.  It's very easily the best £7 I have ever spent on my HiFi and imo has given me an increase in performance that I usually associate with a hardware upgrade of some kind, which sure as heck usually costs a darn sight more than £7.
EDIT: just for info, I've been messing with the params a bit and I've noticed on my Mac that gapless is a problem only if you instruct BitPerfect to upsample.  Leave its preferences set to 'do not upsample' and it works a dream.
__________________
chebby
chebby's picture
Online
Thanks for all the input/feedback.
Alas, I found their FAQ page and it states it doesn't support AirPlay.
Oh well.
It's not as if i'm unhappy with performance from either of my iTunes (far from it) so I shan't miss what I can't use.
__________________
knacker
knacker's picture
does it work on MAC or is it not o/s based
Would help if I read the whole thread ehh, numbnutsbanging head against wall
__________________
Cyrus 6SE CD,Cyrus 6XPD, PMC DB1,Cyrus Interconnect, BIwire speaker cable, Mac Mini,ipad2 & itunes
SteveD
SteveD's picture
Hi, BitPerfect only works on a Mac
__________________
Overdose
Overdose's picture
Is iTunes not bit perfect?
__________________
Mac mini > AVI ADM9Ts
SteveR750
SteveR750's picture
No in Windows, no far from it, but I thought it was in Mac O/S....
Media players like J River bypass the Windows kernel mixer to attain "bit perfection" , I didn't think O/S undertook any resampling / mixing when using iTunes (i.e. the direct exclusive control of the soundcard) unless there is some resampling going in within iTunes of course.
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
Overdose
Overdose's picture
Me too, which makes me wonder why anyone might need Bitperfect?
__________________
eternaloptimist
eternaloptimist's picture
Bitperfect is a lovely piece of software - just does what it says "on the box". Unobtrusive, automatic rate switching, "gets out of the way" when playing compresssed files / internet radio - excellent!
I have tried just about every player software out there on both Windows 7 and MacOS (Mountain Lion) on a dual-booted ("bootcamped") MacMini 2011: Bitperfect, Audirvana Plus, Amara (different versions), Decibel, Fidelia, J River MC, JPLAY.....
In my system, Bitperfect is very nice but I have found Audirvana Plus the best - is not quite so bright and sounds "smoother" - especially female vocals. I suspect my Cyrus and Audiovector system is contributing to this observation and in other systems, Bitperfect would sound better. Incidentally, I found Amara too "muddy"...
Maybe try Audirvana Plus for comparison?
Just my 2 cents...
__________________
Mac Mini 2011 + Audirvana Plus -> Audiophilleo 2 -> Wyred-4-Sound DAC-2 / Cyrus CD 6SE -> Cyrus PreXPd -> Cyrus Mono Xs -> Audiovector S3 Signatures
Overdose
Overdose's picture
But if iTunes is already 'bit perfect' (whatever that really means), then what is an additional piece of software required for?
In addition, what is this additional software doing to change the sound of an already bit perfect program?
__________________
SteveR750
SteveR750's picture
On the one hand I agree, so long as you believe that bit perfection is the right way. On the other hand, if your ears prefer something else, then why not go with that. TBH the latter is soo much easier to verify than the first!
__________________
