Best Coaxial output from laptop...
Mon, Jan 19 2009, 12:04PM
Hi
I want to connect my laptop via a Coaxial Digital output to my DacMagic, what is the best way to do this?
My laptop does not have any digital outputs so what would sound best... an external usb sound card or something wireless like a squeezebox?
Garry
Mon, Jan 19 2009, 12:12PM
#2
Go to Maplin for a "USB Soundbox".
Mon, Jan 19 2009, 12:13PM
#3
Course, you could just connect the DACMagic via USB, though it's limited to 16/44 I think...
Mon, Jan 19 2009, 12:24PM
#4
I'm using Foobar2000 with Vista, the main reason I want to use Coaxial is because I've already got a decent Coaxial cable.
Mon, Jan 19 2009, 12:29PM
#5
LoL @ letting a cable dictate a purchase!
Digital cables do not make a difference.
Get a USB Soundbox which is £15 converts USB to optical. Then use the cheapest thinnest optical cable you can find from a bin.
- Login to post comments
Why does it have to be coax? If there's no digital out, you're right you need another client of sorts - Airport Express will do it (via optical), though only plays iTunes content. An external sound card with a digital out will also work, and a Squeezebox (or other media clients) is a nice option.
What operating system and media player do you use?
CA StreamMagic 6 | CA 751BD | CA 651A | PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
