Audio/Video upgrade to a DLNA solution
5 replies [Last post]
Charl1eB0y
Charl1eB0y's picture
I currently own a Pioneer LX508D Plasma TV connected to a Sky HD box, a Panasonic E30 DVD recorder and a very old 5.1 Yamaha Integrated Amp/Speakers. I also use the Panasonic DVD recorder and the Yamaha Amp to play back my CDs.
I am looking to upgrade my DVD Recorder and Amp to a solution based on DLNA-certified systems that will allow me to:
- Listen to my CDs
- Watch my DVDs and Blu-Ray movies
- Stream downloaded music
- Stream downloaded SD video
- And most importantly, stream downloaded HD video
My starting point is the Buffalo TeraStation Live system. This is where I intend to store downloaded music, SD and HD video.
Could anyone please advise whether the Pioneer SC-LX71 (DLNA-enabled AV Reciever) and Pioneer BDP-LX71 Blu-Ray player would do to achieve those targets?
Would that system compromise the music playback quality (especially CDs)? If so, what are the DLNA-enabled systems (CD players and Integrated amplifiers) that can be added for an optimum music experience?
Many thanks.
PJPro
PJPro's picture
Re: Audio/Video upgrade to a DLNA solution
You could go for a non DLNA amplifer (cheaper) and get another DLNA client device instead. I use the PS3. But there are others.
The PS3 would handle bluray & dvd playback. It'll also play CDs.....although not sure why you'd want to do this as I'd have thought you'd stream your audio files from your NAS.
You'll need to consider the format of the files on the NAS. DLNA client devices won't play all file formats. Are you flexible with the formats used or do you already have a vast number of CDs ripped?
I looked into ripping DVDs to my PC (not legal). It can be done.....but I don't think you get the benefit that you do with CDs. Usually you bung in a DVD and watch it for a couple of hours unlike audio tracks which take about 5 minutes each. Clearly, I deleted the trial DVD file from my HDD once I had satisfied myself that my setup could support it.
__________________
My useful(?) What HiFi Forum threads can be found here.
John Duncan
John Duncan's picture
PJPro:
Of coursh.....
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
PJPro
PJPro's picture
Are you questioning my honesty?
__________________
Gerrardasnails
Gerrardasnails's picture
PJPro:
What a fantastic photo!!
__________________
Screen - Samsung UE46D8000.  Sources - Dell Zino HD 410; Sky HD; Sony BDP S550; Wyred 4 Sound DAC1.  Amps - Yamaha RX-A3010; SimAudio Moon I-3 RS.  Speakers - Vienna Acoustics Mozart Grand; Vienna Acoustics Waltz Grand centre; Proficient Audio W690 rears; Monitor Audio RSW12.  Cables - Van Damme Blue 4mm speaker cable; Townsend DCT300 and Atlas Voyager interconnects; Van den Hul Optocoupler.
Charl1eB0y
Thank you PJPro for your much appreciated input.
My intention is to use the NAS to store SD and HD videos downloaded from the internet, rather than ripping DVDs.
File formats is a good point to consider. Will be doing some more researches into putting that solution in place.
Regards.
