advice soundcard/dac/squeezebox
3 replies [Last post]
chaos mosquito's picture
Hi
I want to hook up my amp to my Dell Vospro 220 computer (dedicated music storage) any advice on what is best for sound;
1. High quality soundcard with an optical out direct to the amp (RV800RDS Yamaha multi channel reciever - no HDMI input)
2. Link computer to the amp via a DAC
3. The Logitech squeeze box system.
I do want to route the music through to other rooms in the future
nads's picture
Re: advice soundcard/dac/squeezebox
Squeeze box and  a DAC.
__________________
Not a HiFi Nut. Just has a pile of Nads.
John Duncan's picture
nads:
Or, seeing as you already have one in the Yamaha, Squeezebox (or similar) direct to that......
Or, if you use iTunes, just get an Airport Express, which provides an optical out and could go round the back of the Yamaha.
__________________
Cambridge Audio StreamMagic 6  |  751BD  |  651A  |  Diamond 9.1 | Minx Xi | Sonos Play:3
Moderator. mail: john.duncan.whf at the mail of g dot com
Thanks for the advice
Chaos Mosquito
