Advice On Backing Up A NAS Drive
4 replies [Last post]
moriarty
moriarty's picture
I have a QNAP TS-210 NAS drive (4TB total / 2TB mirrored) which I'm gradually loading more and more music onto (mostly ripped from my MacBook Pro with XLD in FLAC format).
For peace of mind I would like to have a backup of the NAS contents to store elsewhere.
I'd really appreciate any recommendations for a 2TB portable external hard drive to plug into the NAS once every few weeks, back everything up overnight and then store at my wife's office.
I've been reading through the reviews on Amazon but there seem to be good and bad feedback on virtually every brand & device!
Thanks.
snivilisationism
snivilisationism's picture
RE: Advice On Backing Up A NAS Drive
Thanks.
If it is only for a backup drive, get the cheapest.
I have a similar backup drive. It lives in a fireproof box  wrapped in old clothes under a bed. Is taken out once a month and sychronised. That is all that it gets used for.
All drives from any manufacturer can fail... It is hugely unlikely that both your mirrors AND your backup drive will go at the same time... The only risk I can see is from buglary or fire.
__________________
"In the practice of tolerance, one's enemy is the best teacher." - Dalai Lama
AnotherJoe
AnotherJoe's picture
encourage a friend to mirror your system - offsite backup.
Naughty I know - but this is the real world...
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
snivilisationism
I would echo that. And it isn't naughty. So long as your friend doesn't use the music Smile
__________________
professorhat
professorhat's picture
My personal experience has beem Seagate and Western Digital drives have been more reliable than the LaCie ones. Trouble is, no doubt there is someone out there who's had the exact opposite experience to me!
As has been said, the chances of you getting a failure of both two of your RAID disks and your backup (this resulting in total data loss) are very, very slim. So just go with one which does the job at a reasonable price - even by buying one of the more reliable brands, you've still got no guarantee that it won't fail.
