2.1 speaker system for use with Airport Express base station as part of multi-room solution
No replies
Yammaman
Yammaman's picture
Hi
I have a bit of a bodged multi-room solution at the moment. One room has an Apple TV (v2) hooked up to my main system, one has another Apple TV (v1) hooked up to an old Denon UD M-30 mini system and one more room which runs directly off my mac mini with an AE Aego M setup.
I have an Airport Express base station I would like to use and would like to keep the setup quite simple as it is in the kitchen. I was thinking of buying another set of Aego Ms but although they punch well above their size Im not sure they would fill the room with sound as it is quite big! Can anyone recommend something a bit more substantial than the Aegos? I dont really want to add a separate amplifier...
 Thanks ;)
