Will high end streamers become mainstream?
12 replies [Last post]
Superaintit
Superaintit's picture
Reading this, I just wondered: is it reasonable to assume that high end streamer techology and expertise will 'trickle down' to more main stream devices and so make great music available to everyone?
There are quite a few advantages to streaming over playing discs IMO. Error correction over dlna; my whole library at hand. Also dacs have come a long way..so is basically correct implementation and software all that counts?
Or am I just dreaming and is good quality always expensive?
bigboss
bigboss's picture
RE: Will high end streamers become mainstream?
Which mainstream devices do you have in mind, with inferior technology?
__________________
TheHomeCinemaCentre
TheHomeCinemaCentre's picture
The future is here now. The quality on offer at entry level pricepoints is staggering compared to ten years ago and in ten years time that will be the case again.Quality is a subjective thing but expensive will always be expensive.
__________________
Nick
The Home Cinema Centre
Superaintit
My own. Smile
Reading back my first post I think it needs some clarification.
I now have a streamer costing about 400 pounds. Really happy with it; don't feel the need to upgrade now.
However, having auditioned  the linn majik before (on another system) I can imagine myself upgrading in a few years or so.
Also, after trying different options with streaming I'm inclined to think: how hard can it be? Really. Think about it- no moving parts, dlna error correction...
Wouldn't prices go down and mainstream quality move up in a few years time?
Ie what would hold back the likes of Sonos to reach the high standard Naim,Linn and Cyrus set?
The_Lhc
The_Lhc's picture
The differences are not in the streaming section, they're in the output sections from the DAC and beyond.
It's a bit like asking why doesn't this £50 CD player sounds as good as this £5000 CD player? The transport is likely the same, it's everything after that that's different (ie more expensive components). Logically they're not doing anything differently, it's just the quality of components.
Anyway some people would argue that Sonos actually does a lot of things better than the others you mention.
__________________
No signature worth mentioning...
AnotherJoe
AnotherJoe's picture
If you are playing lossless codecs then there should be no need for a high end streamer.
One of the 1080p media streamers you see available for £100-200 will play jus as well. All they have to do is transcode FLAC into LPCM. Connect it up to a decent AV/Hifi and off you go.
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
Superaintit
So if it's the Dac and output stage that make the difference... still I'm wondering: has anybody had a first hand experience of a comparison between Sonos or squeezebox and 1000+ streamers?
Fuzzy Bear
Fuzzy Bear's picture
Online
CnoEvil
CnoEvil's picture
IMO. A Linn Sneaky is better than both....but these are just meaningless words, unless you try it for yourself.
Nb. I think the Sonos and SBT are both excellent products.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Superaintit
I've not yet compared Sonos/squeezebox performance against Cyrus or linn, but did hear the latter ones in a setup different from my own. Much to the dealers disappointment -bless his soul- I thought the Cyrus was a better match sonically with the dynaudio 110a which I was auditioning at the time.
Btw I did think the linn sounded a bit clearer, but the Cyrus house sound to my ears suited the dynaudio better. Anyway, it was a great product and I'm sure I will try it in my own setup. But only when I got the funds again to allow it  Wink
AlmaataKZ
AlmaataKZ's picture
if you are looking to improve sound quality then looking at the source is wrong. modern sources are nearly identical in quality of output and should be chosen on interface, functionlaity and styling.
as said many times here by people with knowledge, it is the speakers and their interaction with the room and the amp which has the most impact on sound and is the weakest link, by far, in any modern replay system.
study this aspect in theory and in practice - read proper literature and listen to a number of systems e.g. at a show, paying attention to sound (and not to brandname/pricetag). then you know where to spend if spending is in your plans.
daveh75
daveh75's picture
Online
Personally i think streamers are best left to those that know what they're doing (Sonos et al) Most of the hifi solutions are lacking in function/format support or the UIs are pish...
__________________
JVC DLA-X30•Grandview Cyber Series (92")•LG 50PX990•Oppo BDP-93•Humax Foxsat HDR•Humax HDR-Fox T2•Vu+ Solo²•WD TV Live•Onkyo TX-NR818•Mackie HR824 MK2•BK Monoliith DF
Sonos Connect•Studiospares Seiwin 5A
Superaintit
Well, that is exactly what I was thinking and where I put my money.
That and the high end streamers was actually the thing that prompted  my initial question.
