Streaming from Jriver MC18 to Marantz M-CR603
2 replies [Last post]
pompousmax
pompousmax's picture
Hello all,
Having finally grown tired of the restrictive nature of Itunes I have moved to Jriver MC18. It is an excellent piece of software allowing great flexibility and the convenience of playing most audio files with no issues. I'm using it with a Dragonfly USB DAC and the real advantage here is how the correct sample rate is detected and displayed by the colour LED on the Dragonfly accordingly. Used with the Soundmagic HP100 headphones it's a very rewarding experience! Nice. Cool My problem is this, I can't get the MC18 to stream my audio files to my Marantz M CR603. I've been using Airplay with no problems, but really wish to move away from Itunes to allow me to play FLAC and Studio Masters through the Marantz. I suspect there maybe an issue with the DLNA settings with the options on the Jriver, but I can't ascertain what !?
Is anyone managing to stream any audio files successfully using Jriver to the CR603? If so what setting adjustments do I need to make? Any suggestions will be greatly appreciated. Many thanks.
SteveR750
SteveR750's picture
RE: Streaming from Jriver MC18 to Marantz M-CR603
Have you posted the question on the JRiver forum? I've found you'll get a quick answer, and usually it's the fix.
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
pompousmax
Thanks Steve, I'll give it a go.
