Spotify and Nas
12 replies [Last post]
gingersmarty
gingersmarty's picture
Firstly apologies i appear to have posted this in the wrong place earlier   embarassed
Hi All
I usually listen to Spotify wirelessly using an ATV onto my set up. I have noticed an improvement in SQ
when i connect my laptop to my DAC through the USB and a V-link then onto my set up.
 Is it possible to use NAS that is wired to my set up and listen to/control spotify via my laptop wirelessly.
thanks in advance.
__________________
HI-FI - Sony Vaio(Spotify)->Apple TV->TCI Coral->Rega Dac->Chord Chameleon Silver Plus->Cyrus Pre XVS->Chord Chameleon Silver Plus->Cyrus X Power->Chord Odyssey 2->Spendor SA1.
TV - Panasonic TX-P50GT60 - Onkyo SR606 - Panasonic BDT310 - Kef 3005SE
roger06
roger06's picture
RE: Spotify and Nas
Sorry if I'm being thick, but I've read your post four times and can't work out what you're asking!
__________________
Synology DS212J-> AppleTV->  rDAC->Naim Nait5i. Dynaudio Audience 52SE
Sony BDPS370 / YouView ->Yamaha RXV1065-> Pana TH42PX80B plasma.
The_Lhc
The_Lhc's picture
RE: Spotify and Nas
Yes, why do you need a NAS to listen to spotify?
__________________
No signature worth mentioning...
gingersmarty
RE: Spotify and Nas
Hi
Can i connect Buffalo Link Station to my Dac and play/control spotify sat on the other side of the room, using my laptop, without my laptop being physically connected to anything as i do using the ATV currently.
thanks
__________________
roger06
roger06's picture
RE: Spotify and Nas
Spotify's on your Vaio ?
__________________
gingersmarty
RE: Spotify and Nas
Hi The LH_C
I obviously dont need a NAS to listen to Spotify, however on the odd occassion i have used the a USB cable from my laptop through a V-link onto my set up i feel the SQ is improved and wondered whether removing the ATV would be benficial, as you can obviously tell i do not fully understand how large sections of my current set up actually work - technically.
so advice or comments in simple terms would be appreciated.
thanks
__________________
gingersmarty
RE: Spotify and Nas
Hi
thats correct
__________________
roger06
roger06's picture
RE: Spotify and Nas
And what's on the NAS?
__________________
gingersmarty
RE: Spotify and Nas
nothing at the moment
__________________
roger06
roger06's picture
RE: Spotify and Nas
I'm having fun playing 20 questions...Laughing
I'll tell you how mine works and see if that helps.
I have all my music ripped as Apple Lossless onto my MacBook Pro. This is duplicated onto my WD NAS. To listen to this I use a jail broken ATV 2 running XBMC. This outputs via optical to an rDAC then Naim amp. SImple.
When I want Spotify I have a couple of options but easiest is to run it on MacBook Pro and stream it to ATV using AirPlay using an app called AirFoil on the laptop - I don't know if there's a PC version or something similar.
But, your NAS is going to have nothing to do with Spotify...
__________________
gingersmarty
RE: Spotify and Nas
hi roger06,
I'm glad your having fun, life is better with fun.
I currently stream using Airfoil and the ATV optically onto the dac, i was wondering whether i could use a NAS to use the a USB connection to the Dac, however i get the funny feeling that a further game of 20 questions will only highlight the lack of understanding of how most the boxes in my front room work.
excellent!
__________________
roger06
roger06's picture
RE: Spotify and Nas
Right, I get you now!
I don't know your NAS - but I very much doubt it'll do this. It's 'network' storage so ethernet is the way data gets to and from it. My WD has a USB port but this is for connecting a USB hard drive in order to increase storage, it's not for output.
Also - even if it was possible, there's no streamer, ie nothing to control the data from NAS to DAC so no, it wouldn't work.
__________________
gingersmarty
RE: Spotify and Nas
thanks roger06,
I would say i thought as much, however that is patently not true,
thanks beauty, eh again
__________________
