5 posts / 0 new
Last post
lpv
lpv's picture
Last seen: 1 month 3 weeks ago
Soundflower/ AU Lab
Hi all.
just started using Soundflower/ AU Lab combination to take adventage of the global Mac equalizer, however is there's any chance I can remotly ( from iPhone) control the AU Lab equalizer?
shooter's picture
Last seen: 2 years 8 months ago
RE: Soundflower/ AU Lab
I use AULAbs and no it can't be remotely controled.
Once you've found the balance would there be a need  :quest:
lpv
lpv's picture
Yes, true.. I'm experimenting with settings.. all I need is a bit of boost around 50Hz, the application seems work just fine.
At the moment I'm sending signal out of my Mac via optical/ digital out and that means cable... any chance to set up AULab in a way so I can stream equalized signal via AirPlay?
shooter's picture
Not that I found.
I did come across a hack called RaopX which can hijack the audio and adds a 9 second buffer but i couldn't get EQ on the stream. To be honest its not particulary user friendly as its all done through 'Terminal'
If you happen to give it a go and work it out let us know.
lpv
lpv's picture
Just an update.. you can now use AU Lab and AirPlay at the same time with Mavericks OS X
Log in to post comments
