So much for 'finished ripping'
8 replies [Last post]
MajorFubar's picture
Found a load of albums I ripped in late Jan/early Feb where the last few of tracks on each album 'skip' st some point, for no reason.
Well I say 'for no reason', I point the finger of blame at my USB drive, which seems to be prone to mistracking at the end of long (74 min+) CDs.
I'm having to re-rip the last one, two or three tracks on what could be as many as a 100 CDs. Lovely.
Complicated further by the fact I've already made three back-ups of my library: one exact copy on an external HDD and two MP3 copies, all of which need manual-syncing every time I re-rip.
See that check-box in iTunes which says 'Use error correction'? Well it appears to do slightly less than naff all.  banging head against wall
__________________
Main system: Mac Mini 2011 • HRT II+ DAC • Lacie 3TB Cloudbox NAS • Marantz CD63KIS • Marantz PM66 KI • EB Acoustics EB2
In storage: Thorens TD160 (no cart) • Cyrus 2 + PSX • Cyrus tuner • Technics SL-P777 • Nakamichi DR-1
daveh75's picture
Online
RE: So much for 'finished ripping'
I've said it time and time again, ripping is a laborious and tedious job.
So regardless of what media manager/player you use, for ripping use the proper tool for job, i.e one that does secure/accurate ripping not some crud that you put a tick in a box to turn on 'error correction'...
__________________
Yeah I tried that too, using XLD, which does do accurate rips but for me the tags and album info it got were often all to fEDITEDk, possibly because it seems to scan every known source except Gracenote, which is what iTunes uses. I did use XLD a lot towards the end so I could make lossless and MP3 copies simultaneously, but I certainly spent more time correcting the tags than with iTunes.
__________________
professorhat's picture
Online
I was worried about this - to check the issue, I just used to do one day of ripping, then one day of listening (generally while I was working, so not dedicated listening, but enough attention being paid that I'd notice a big skip or issue with the track). That way I listented to every track of every CD that I ripped pretty much the day after I'd done it to ensure it had ripped properly. Two benefits:
1. You have a day off ripping every other day
2. You listen to a lot of music in your collection you probably wouldn't normally listen to
I think I only had a couple of tracks which were no good and no amount of re-ripping would have fixed the issue as the CDs were just old and scratched. I also used iTunes to rip my collection and it was absolutely perfect for the job.
Yeah it's probably my drive, and probably XLD would have done no better than iTunes, but if iTunes had WARNED ME about all these badly-ripped tracks at the time of the ripping, I would have been a much happier person. Sorry yes I am a bit pee'd off with the process and specifically iTunes' 'lack of communication'.
__________________
Other than the errors (I *think* I've found all of them) I found another batch of CDs I hadn't ripped.  banging head against wall
Well I say 'found'.  I sort of always knew they were there, but I deliberately missed them first time round because I figured I'd never play them.
Then there comes a time when they're the only ones left 'un-ripped' and I thought, ah what the heck; may as well get them ripped & slapped on the hard drive with the rest.
And I probably still won't ever play them. But leaving them up-ripped makes me feel I've not fully completed the job.
I know. Get a life.
__________________
Overdose's picture
OCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCD,
OCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCDOCD....
I'd do that too.  Wink
__________________
Mac mini > AVI ADM9Ts
drichardb's picture
Audiograbber FTW, it might be slightly old but by god that thing can rip
__________________
My Setup
Alec's picture
Wish I'd thought of that, Prof. I found a song that sounds liek a broken record recently, "even" after riping with DbPoweramp. I'll just fix the situation as and when now.
__________________
Formerly known as al7478...
HC: Panasonic PXP 42 V20; Panasonic DMP BD35; Humax Foxsat-HDR
Music: Optical out from Asus P7H55-M Motherboard into AVI ADM 9.1 speakers.
"Music will provide the light you cannot resist"
