4 posts / 0 new
Last post
Mattan's picture
Last seen: 4 months 1 week ago
Ripped CDs Quieter??
I've been listening to my finally ripped CDs on a Sonos Play:3.  They've been ripped as MP3s (VBR V2) and a few as FLAC.  I'm not sure if it's the rips or the Sonos, but they seem quieter than the orginal CD.  I'm playing the CDs from a separates system and and old 'ghetto blaster'.
I'm using EAC/LAME to rip to MP3.  Is there any way to get the violume higher.  Why would they be quiter?
BenLaw's picture
Last seen: 1 year 11 months ago
RE: Ripped CDs Quieter??
How can you tell they're quieter if you're playing them back through different systems?
I am the danger.
chebby's picture
Last seen: 23 hours 8 min ago
CD transports make noises. Not much noise admittedly, but it might account for the difference.
[EDIT] Ok just noticed you didn't mean background noise. You mean the signal level is lower when playing back files - rather than CDs - so you have to turn the volume up more.
Can you plug the CD player (from your seperates system) into the Sonos Play 3 so you can compare properly?
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
Mattan's picture
@BenLaw:  My 'ghetto blaster' is an old panasonic stereo and not particularly powerful.  The volume just seems higher on this than the Sonos.  I have to crank the latter up comparatively more.
@chebby:  Unfortunately, then Play:3 doesn't have a line in, so can't do the comparision.  I do have a Revo Mondo wi-fi and this is plugged in to the same amp as the CD separate.  Same issue - I need to turn the volume up higher when switching from CD player to MP3.
Log in to post comments
