Re-compressing or converting mp3s
5 replies [Last post]
Overdose
Overdose's picture
I think that I've asked this question before, but here we go again.I have an iPod Classic 160GB and it will now no longer take any more music as it is full. My music is stored as ALAC files on my Mac mini and NAS and my laptop and iPod have 256 Kbps VBR mp3s.My question is, if I further compress the 256 library to 192 to fit on the iPod, will there be any chance of creating a noticeable change in sound quality other than what might be possible to distinguish as a straight 192 rip from a CD?I'm not convinced that at 192 Kbps AAC, I would be able to tell any difference from a lossless file in the first place, but in this instance, the files are being compressed further or re-compressed.
__________________
Mac mini > AVI ADM9Ts
AnotherJoe
AnotherJoe's picture
RE: Re-compressing or converting mp3s
Compress from the origin ALAC to the new rate.
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
daveh75
daveh75's picture
Online
Indeed.
Why re compress when you have the original ALACs.
__________________
jjbomber
jjbomber's picture
Have a listen on iRadio to Rock radio 1, as they broadcast at 192. Kbps. That will tell you standard and only you can then determine whether it is good enough or not.
Secondly, you can set the sync to 192 but keep the original files on your various PCs as ALAC. If you don't like the 192 sync, you can always sync again at the higher rate with less tracks on.
I have exactly the same problem. Incidently, I find that syncing from ALAC to a lower bit rate takes forever. I was about 36 hours last time a did a full sync, whereas it is about 2 hours when they are left at ALAC.
Overdose
Overdose's picture
Ah yes, found it. Files deleted and auto re-synced at 192. It's largely academic really, as the library is too large to fit at 256.
Many thanks.
__________________
Overdose
Overdose's picture
Hmm, 36hours and then some I reckon.
Change of plan. I'm now using XLD to reconvert all files from ALAC to 192 VBR AAC. ALACs will still be for archiving and home use, the AACs for music on the go and generally carrying around.
__________________
