5 posts / 0 new
Last post
Pete Shields's picture
Last seen: 1 week 4 hours ago
Raspberry Pi and Wolfson sound card - hi res sound?
I am looking at finding a way of streaming Hi Res Audio from my NAS drive to my DAC.
Has anybody managed to get this working on a Raspberry Pi with the new Wolfson sound card?
If it works, it would be a really good cheap solution.
Audiolab M-Dac/M-Pwr/Sonos Connect & Cyrus 6s CD and a Pi with RuneAudio playing HD. Tannoy Rev DC6t Se's and Senn HD650's.
Sony STR-DN1040 receiver, Sony BRP 7200, Nvidia Shield Tv & Kodi and Tivo. And Bose 5.1 cubes.
daveh75's picture
Last seen: 3 days 18 hours ago
RE: Raspberry Pi and Wolfson sound card - hi res sound?
If you only intend connecting to a standalone DAC wouldn't the HiFiBerry Digi be a better option?
http://www.hifiberry.com/hbdigi
Thanks for the advice Dave75. I'm a little offput by the need to solder though - even though it says its easy I'm bound to cock it up. Looking at the Wolson one, I coud get a fully setup PI for well within a ton. A few of the guys I work with use them, as XBMC streamers too which would also be of great use within my media centre.
I suppose the question for the forum before I consider further, is has anybody tried playing Hi Res tracks through a Raspberry Pi system and what's their views on it?
my posts seem to be repeateing themselves. The forum seems to have gone a bit clunky since I last used it. It kept on freezing, hence all of the repeat posts, which I will now attempt to remove!
Log in to post comments
