Acoustic Energy reveals 250 limited edition AE1 Mk III SE speakers
Acoustic Energy AE1 Mk III SE
The speaker is offered in three finishes: an eight-layer, hand-finished piano black or pearl white, or a cherry real wood veneer. And if that's not good enough, AE will even do you a custom paint job.
Designed and built in the UK, the AE1 MkIII SE uses a heavily braced 18mm MDF cabinet, lined with a 4mm steel plate, while the 12mm baffle is solid aluminium.
The bass driver uses AE's spun-alloy cone inside a die-cast magnesium alloy chassis, coupled with a 38mm ring-radiator tweeter. Elsewhere there's also a completely redesigned crossover.
The piano black and cherry wood speakers will set you back £2500, or save up £3250 for a pearl white or bespoke finish.
