4 posts / 0 new
Last post
sogophonio11's picture
Last seen: 2 years 10 months ago
JRivers default location
Any one use JRivers MC? Can you tell me how to set the default for looking for music files. My PC has two internal hard drives, want to use :C: for all the system and all other downloads, and:D: just for music. Tried Tools>Options>File location. But after ripping some CD,s went onto :C: And  drive:D: is still empty!
Many thanks.
his dudeness's picture
Last seen: 4 days 17 hours ago
RE: JRivers default location
should be tools-options-file location,i think create new folder,ive never tried but that should be the place to do it.
lg55b6v oled,oppo uhd203,sr7008,tannoydc6tse,dc6,d6lcr,dc6,svs sb2000,humax hdr1000s,synology ds213j,nexus 5&7
Thanks his dudeness, will have another go then.:quest:
basshound's picture
Last seen: 2 weeks 11 hours ago
I have JRiver MC 18 but other versions should be similar I think, Tools>Options>File Location, in right hand pane under Audio the first option lets you browse to the location you want your music to be stored,in your case D (folder name) something like music or cdrips should do. This will put any cd rips in that folder, then Tools>Options>Library&Folders click on configure auto import and then Add and browse to the folder you created earlier. If you have any music stored elsewhere on your computer put it all in this folder,run auto import and JRiver should find all your music and also should update itself as you add more music to that folder.
        Hope this helps if you haven`t worked it out already!!
Synology DS213j NAS>JRiver 21 >Auralic Vega> ATC P1 >ATC SCM 40`s + BK Electrics Monolith Plus sub
Log in to post comments
