How do I iTunes to sort my comps in Numerical order
8 replies [Last post]
dx052
dx052's picture
I have a compilation of albums from vol 1 to 50 (think of the Now Series) and when I add the folder 1, 2, 3 etc for each album into Itunes it gets confused when I past album number 10. I want the lsit on Itunes to run the albums in series of numbers 1-50. Anyone know how to do this? been searching everywhere for the answer. many Thanks
__________________
Technics SL1200 MKII > Ortofon 2M Blue > Cambridge Audio 540p>Pioneer A400 >Pioneer PD S801 > Mission 753
Overdose
Overdose's picture
RE: How do I iTunes to sort my comps in Numerical order
Yes, bulk edit the tracks so that the album title is in numerical order. Bulk edit to save time, select track 1 then holding 'Shift' select last track on album. Right click, select info and edit metadata for album title.
__________________
Mac mini > AVI ADM9Ts
dx052
dx052's picture
I Think i am with you!! All my Metadata is already there. Each album is numbered Vol 1, vol 2 etc etc in the info section. when I add folder (vol number) 10 it places that album after number one instead of after number 9. Sounds confusing I know, but cant seem to suss it..
__________________
John Duncan
John Duncan's picture
Online
Volume 01, Volume 02, Volume 03... will fix it.
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
Overdose
Overdose's picture
Yes, it probably would. My library however, doesn't exhibit this behaviour. Are you on Windows?
__________________
dx052
dx052's picture
Yes I am on Windows, Been scratching my head on this one. Will try the latest recommend. Thanks
__________________
John Duncan
Online
Not by default it wouldn't no, but you can rename the albums, Shirley?
__________________
Overdose
Overdose's picture
It's worth noting that there are many ways in which metadata can be sorted by iTunes or other media players and also, many different fields of information for the metadata. It takes time to get it just how you want, but it's worth the effort in the end.
__________________
Overdose
Overdose's picture
I meant my library lists album 10 after 9 and not after 1. Are we talking crossed purposes here?
puzzled
__________________
