AVA Media rip n play
20 replies [Last post]
pete.g
pete.g's picture
Hi guys
I am interested in purchasing an AVA Media rip n play to store my cd collection and serve my NaimUniti. I presume they are compatible - maybe someone can correct me on this. I have gone down the NAS route before with the Synology DS 211J but after I eventually got it working and transferred my music files ( not really tech savvy ) the motherboard failed. I always intended getting a Unitiserve but at over 2K it is just too rich for me. Has anyone tried the "rip n play" ? It looks like a well built piece of kit and may last a decent time but haven't seen any reviews yet.
__________________
PDPLX5090 Kuro. Denon 2310. Denon 2500BT. SHYHD. B+W684's front 686 rears HTP62 centre SW150 sub. AppleTV. Harmony one. NaimUniti. Ava media rip n play 1TB.
John Duncan
John Duncan's picture
RE: AVA Media rip n play
I've seen one in the flesh and it's certainly beautifully built (bit like current Audiolab kit), and fills a gap for those who think the Unitiserve's a great idea but stupidly priced (eg me).
Of course, some will argue that this is stupidly priced as well and that you can do the same thing with your existing PC (or Mac Mini, say), which is pretty much true, but if you want to separate concerns and want it in a nice box, there isn't much around like it.
I'll try and blag one and let you know Laughing out loud
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
David@FrankHarvey
David@FrankHarvey's picture
Online
I'm going for one myself. I loved the build quality of the unit and its flexibility, and althou I have a NAS drive, I hate the hassle of ripping to my laptop and then transferring to the drive. This is going to be extremely simple, and may mean that I can do away with my laptop altogether. I'll hopefully be getting it soon, and we'll also be using one in store instead of a WD NAS we currently use.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
pete.g
pete.g's picture
thanks for the response guys
I've gone ahead and ordered it so should have it up and running by the weekend. Hopefully it performs as i hope and i can eliminate my laptop from the equation when streaming. I understand that there are cheaper solutions out there for streaming but as i was possibly thinking of adding a UnitiServe at some stage, this could be a bargain. I'll post my first impressions when i get it set up.
thanks again.
__________________
pete.g
pete.g's picture
Well my Rip n Play arrived yesterday and I can quite honestly say I'm amazed. It just does exactly what it's supposed to do ( which in my experience is not allways the case) It was connecteted to the server and powered up in 2 minutes and took 4 minutes to rip my first cd inc artwork. So within 10 minutes max I was streaming to my Uniti working seamlessly with the N-stream app on the iPad/phone. I understand it's an expensive piece of kit and those more tech savvy can find a cheaper route but I'm more than willing to recommend it. Cue many days of ripping!
__________________
CnoEvil
CnoEvil's picture
This is the very reason I like my RipNas....great job!
Cno
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
John Duncan
@pete.g - is it possible to copy already-ripped stuff onto it? I don't fancy ripping the ~100GB of music I already have again...
__________________
Andrew Everard
Andrew Everard's picture
"The folders made available on the RIP-N-PLAY root are all READ-ONLY, apart from any folder found under the FILES folder.
While you can transfer from any folder found on the RIP-N-PLAY, you can only transfer to folders found within the FILES folder.
Below is an example of transfering an mp3 file to the RIP-N-PLAY using a Windows 7 PC:
-          Click on the Windows Start Button and in the search field type \\ripnplay and then Enter
-          A new Explorer window will open, showing the contents of the RIP-N-PLAY.
-          Navigate to the  Files Folder as all other folders in the root of the RIP-N-Play are Read-only
-          Navigate to the folder where you would like to transfer the files to. In our case \\files\music\mp3
-          Open the local location where you would like to transfer the files from
-          Using drag and drop or copy and paste, copy the files from the local location to the RIP-N-PLAY selected folder"
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
John Duncan
OK, but does it then scan and assimilate those tracks into what I presume is an internal metadata DB? Have you got one Andrew?
__________________
Andrew Everard
No, not yet – the nice PR person Wink has offered one for Gramophone, but have been too busy to arrange to have it delivered/pick it up yet. Must get round to it next week...
__________________
David@FrankHarvey
Online
I've been filling our demo one up for the last few days - as already mentioned, very simple and super fast to set up and start using. Now where did I put that credit card.... Smile
__________________
pete.g
pete.g's picture
Just to update. Apart from streaming to the Uniti I can now access the Rip n Play library from anywhere on my iPad/phone using the subsonic app. Also extremely easy to set up. I'm playing music on another system through Airport Express via AirPlay. I love it when these things just work Smile
__________________
Jacko
Jacko's picture
I am intrigued by this - anyone else seen/heard/bought it ? Very interested in any additional feedback.
David@FrankHarvey
Online
Only a matter of time before one makes it into my system - I have a few other priorities at the moment through.
__________________
Jacko
Jacko's picture
Andrew - did you ever get to play with one of these ? Anyone else ?
Jacko
Jacko's picture
Any more input on this ? thanks
