25 posts / 0 new
Last post
Big Aura's picture
Last seen: 1 week 3 days ago
Audi MMI / SD Card
Hello all
I've recently bought a 2010 model Audi A6. Apparently there were a number of audio specs available on this car when originally sold, the previous owner chose CD multichanger rather than iPod interface for the MMI.
To install an iPod interface means ripping out the glovebox mounted CD changer and paying someone £200-300 to install the iPod gubbins, which I'm not overly keen on.
There is another option. The CD changer has an SD card slot which can be used for music. Now, from casual reading of the web, this seems to be very complicated and results are mixed. My iTunes library is a bit of a mishmash of formats (mp3, mp4, lossless) and I understand that not all formats are supported.
What I'm hoping for is that some forumite has been down this road (in an Audi) before - is there a simple way to transfer my iTunes library (including album art and track listings etc.) to an SD card that will "work".
Please bear in mind that I can be a bit of a luddite at times, so moron-friendly pointers much appreciated!
thanks
Overdose's picture
Last seen: 2 years 2 months ago
RE: Audi MMI / SD Card
This question is on the wrong forum really and most people wouldn't have a clue.
There are quite a few aftermarket add ons to VW Audi head units which allow iPod functionality. I have just retrofitted an A6 navigation system into my A4 and added iPod cennectivity, including charging. It's not too tricky to fit yourself. A cheap option would be an iPod FM transmitter adapter which simply clips onto your iPod connector and then acts as a transmitter which your radio picks up. That was £10.
Try the VWAudiforum and also have a look at the 'Connects2' products for starters.
What head unit do you have? The solutions will differ depending on existing connectivity.
You also might need to hook up to a VAG Com or RossTech interface to reprogram some functions (users can be found across the country on the VWAudi forum).
SD card and other info.
Andrew Everard's picture
Last seen: 3 years 5 months ago
Big A
Migfht be worth a post on Pistonheads' Audi forum...
Overdose's picture
Big Aura's picture
Hello, thanks all.  I've got the standard unit that was issued in 2010 (not sure what it is, tho).  That said, I read last night that the SD slot won't read an SDHC or SDXC card.  And then, true to form, I read somewhere else that it will.  I'm going to muddle through, and report back!
pauln's picture
Last seen: 2 days 22 hours ago
I use the SD card in my Audi, the sat nav device has two slots - it's fantastic having so much music available with no CD cases cluttering up the car.
Anyway I may be able to help a bit. Mine is definitely limited to using standard SD cards but it's a late 07 model so yours might handle SDHC cards as it's a bit newer. The standard cards are so cheap you could just use them or else get an SDHC card and see if it works. It will only play mp3's, the easiest is to copy and paste the mp3 files onto the card then use something like "Playlist Creator" to make playlists. That is the Windows way - Mac may be different but there must be similar software? It really is so simple to do on a laptop with a card reader.
The music you have in other formats can be transcoded using one of the freeware apps out there although going from lossy to mp3 might mean some loss of quality. I used Foobar to batch convert my flac library to 192kbps (keeping the original files obviously) into another folder. I can now just move stuff onto a few SD cards, do the playlists and pop them in the car. I get about 30 albums onto a 2Gb card.
Hope that may have been of some use.
jmjones's picture
Last seen: 17 hours 56 min ago
Duplicate
Oppo 105eu, Tag McLaren AV32r (reintroduced with by-pass), 100*5R, Pro-Ject turntable, Monitor Audio 20se/gold centre & surrounds, custom HTPC, Sony 9405 75" TV, Sky HD, Pinnacle Audio Folio (No? Look that iron up!)
jmjones's picture
Pauln is spot on with his advice. I have a 2010 model and it is the same. I used Mediamonkey to batch convert various files to MP3 and then dropped them onto a standard card. There are limits on size of card and number of files on one card. If memory serves, the head unit will only recognise up to 4000 files.
Good luck with it.
Big Aura's picture
Pauln and jmjones, thanks a lot.  Really helpful.
I bought a 64 GB SDXC card, which my laptop (5 year old Dell) scratched its head at, and meanwhile I read the instructions for my MMI and it's capped at 32GB (so SDHC) and, as you note, 4000 tracks.
I've ordered a new card.  In terms of format, then, do I just plug it into my computer, drag and drop my iTunes into it and then use that "media monkey" think to convert them on the memory card to mp3?  Or do I need to replicate the folders on the computer and convert them there (a slight problem as my harddrive is mostly full).
thanks
pauln's picture
RE: Audi MMI / SD Card RE: Audi MMI / SD Card
If the tracks are already in mp3 format, just drag and drop onto the card. If you need to convert then I'm pretty sure that you can make the SD card the destination for the converted files so you won't need to duplicate the files on your hard drive. I don't know how it works with DRM, itunes and copying files - all mine are ripped from my CD collection so I don't have that issue.
As to file structure; what I've done is create a folder on the SD card for  each album with all that albums tracks in it. This makes it easier to find stuff, you could if you wanted have a folder for each artist and sub folders for albums or whatever. When you do the playlists you just select the tracks you want from the folders on the SD card, put them in order and save the playlist on the card. The title that you give to the playlist is what will appear on the screen in the car.
Big Aura's picture
ahh (and I refer to my earlier-mentioned computer illiteracy...), does this mean I need to create sub-folders and individually copy albums across, choosing whether/not to convert to mp3?
I had hoped for a magical program that would replicate everything (incl art) and take it across simply and (more importantly) in an idiot proof fashion!
pauln's picture
Well' I don't know that you need sub-folders. I found some help on the Audi forum and it seems that the system (at least the 2007 version) can not browse a file structure as you would find on a computer; hence the reason for having to make playlists. I did one for each album. That means you can just select all the folders as they are on your computer and copy them en masse onto the card; provided that  they are mp3's.
Then you do a whole load of playlists as you see fit - I did one for each album. The display in the car allows you to scroll through the playlists and select one or even one track from a playlist. You can select random play as well I think but I've never tried.
Maybe there is one - try a Mac users forum, it is Mac software after all and I can't help you with that. I wouldn't have it anywhere near my computer to be honest.
Why do you want album art in your car?
motley's picture
Last seen: 7 months 2 weeks ago
Do you have the option to stream audio vis Bluetooth? if so you can buy a dongle to fit any iPod classic.
Alternativly a Parrot 9000, 9100 or 9200 will give you Bluetooth, USB and iPod conectivity (with integration to OEM steering wheel controls if fitted) or dear alternatives are available from Fiscon.
jmjones's picture
Unfortunately, things are never so simple:
Album art won't display in my car, and the music navigation system is a loooooong way behind an ipod! Get the passenger to do it.
On file conversion, I've used Mediamonkey and Winamp -  to perform file conversions you need the paid/pro/gold version of the software. Highlight any selection of tracks, albums and artists, then use the "Send To" command (Mediamonkey). Set conversion parameters for MP3 quality, and you can output straight to the SD card if you wish. Takes a while.
You can "drag & drop" or "Cut & Paste" MP3s direct. Saves time
jmjones's picture
Duplicate
Big Aura's picture
thanks Mark.  32gb card arrived last night, so will have a go at the weekend!
Pages
Log in to post comments
