Apple tv3 output question
4 replies [Last post]
smuggs
smuggs's picture
I have it connected hdmi to my denon1909 but if i also take an optical to my dacmagic would it auto detect the one trying to use or would i have keep going into the settings
__________________
Samsung 46 led tv-denon1909-skyhd-wd tv live -wd my book 2tb nas-apple tv3-xbox360-accer 7540 laptop-dac magic-genie2(2mred)-Montior Audio Br5's Br-LCR Br1's Brw10 sub-ipad(2g)-samsung gs2-akg 450's
Juzzie Wuzzie
Juzzie Wuzzie's picture
RE: Apple tv3 output question
It should send the signal to both at the same time (i.e. through the HDMI and the optical).  Not sure if that is what you need or a p.i.t.a.
__________________
Living Room: Samsung 40C7000; Oppo BDP-103EU; Onkyo SR308; Apple TV3; Airport Express; Sky HD+; Jamo A102 HSC5; Naim Nait 5i-2; Neat Iotas; Chord / Wireworld / QED / TCI interconnects and speaker wire; Harmony 550 universal remote; Tacima mains conditioner Portable: Shuffle (1G); iPad (1G); iPad Minil FiiO E1; AKG450; Grado SR60i; Sennheiser CX300II; custom Ultimate Ears Car: iPod Classic 120GB
smuggs
smuggs's picture
Happy days ill order one all i want to do is use the denon atv3 setting hdmi for airplaying you tube and home sharing my itunes movies but id like air play itunes music and spotify to my dac magic cause it sounds better and i have set an input on my denon as dacmagic with 2 channel and use pure direct so thanks for the fast help
__________________
Juzzie Wuzzie
Make sure you don't fall foul of auto-switching (if any) on your a/v amp as it may detect a signal from two sources at the same time.  My problem is the opposite - I run HDMI into an a/v amp, and optical into a hifi amp - meaning I need to completely switch off one when using the other.  First world problems I guess.
__________________
smuggs
smuggs's picture
Never thought of that i do leave the dac magic on 24/7 as it seems to cool that way. But im hoping that by selecting the input on my avr amp that it will know what i trying use.
__________________
