Upgrading, need experts help!
2 replies [Last post]
jamaza
jamaza's picture
Hello guys, so it's time to upgrade my home cinema and needed experts advice, at the moment this is the set-up i have:TV: Sharp 52" 1080p, model: lc-52xl1e   Spec: HEREDVD player: Pioneer DV-400V Spec: HEREAV receiver: Pioneer VSX-917V Spec: HERESpeakers: Pioneer 5.1 S-SP410The whole setup excluding the TV cost me around £1000 around 4-5 years ago. The main reason i am upgrading is because the dvd player when playing a movie through a USB/DVD jitters a lot on certain scenes which have a lot of the same colour in, for example ocean, or trees in the forest, or sand in deserts, anyway you get the idea. I believe i only need to upgrade the DVD player and im looking to spend around £500. I want experts advice on what is the best DVD player to get for my money, the key features which i will require is for the DVD player to be able to play movies from my Hard drive through USB or if possible i would like a WIFI and play movies that way. Im thinking whever i should buy an older top range dvd player or a high range new dvd player. Here is some of the dvd players which cought my attention:
http://www.ebay.co.uk/itm/190764237410?ssPageName=STRK:MEWAX:IT&_trksid=...
http://www.ebay.co.uk/itm/330838628952?ssPageName=STRK:MEWAX:IT&_trksid=...
http://www.ebay.co.uk/itm/190648131834?ssPageName=STRK:MEWAX:IT&_trksid=...
Please let me know what you guys think and please advice me in this situation!Any help appreciated, Thanks!
AnotherJoe
AnotherJoe's picture
RE: Upgrading, need experts help!
First of all - is the jitter down to the motion settings on your TV. I would suspect it is.
But if not, and you really want a new player I would suggest spending up to around £200 on a new blu-ray player.
I wouldnt spend £500 or so on a dvd player that is around 3 years old. Technology has come on a long way from those players you link to, and you can get a lot more for a lot less now.
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
duaplex
duaplex's picture
For £200 you could buy the Sony S790.  If you keep track of my thread, David and myself are about to review the Oppo 103, as soon I demo it I will report back.  I am in a dilemma as to whether I should spend above £200 purely for bluray playback.
__________________
Panasonic 65" 3D TV (P65VT50), Pioneer LX83, CA, Azur 751BD, PS3, Water Cooled Xbox 360 (Modded), Nintendo Wii U, Sky HD+, i7 PC overclocked with 6850 HD Radeon, CM8 Fronts (Bi-Amped), CMC Center (Bi-Wired), DS3 Dipoles, PV1 Sub. Van Den Hul M.C. Snowtrack >Halogen Free< wiring, Chord Active Silver HDMI's, Cabridge Audio AUD700 Analogues Interconnects, QED Signature Subwoofer cables, Chunky Monkey custom oak AV cabinet.
