Thor 3D won't play
3 replies [Last post]
KiwiMoto
KiwiMoto's picture
Just leap into 3D this week.Picked up a new Pioneer BDP 450 player and two 3D discs.Played the first one,Coraline,with no problems at all in 3D.Then for the main event Thor 3D!
But alas,all I get is a screen saying I need a 3D comparable player,blah blah...
I plugged in Ethernet to check for the latest firmware but it is current according to the player,ver 2.05.
So what do I do now?Anyone else had a problem getting this 3D title er,um,Thorted? Smile
__________________
Panasonic PT AE8000*Yamaha Aventage A3020*Pioneer BDP 450*Project RPM 9.1*Dynavector P75*Klipsch RF/RC/RS 62 II*Klipsch RS41 II front height/rear surrounds*Velodyne SPL1000Ultra*Da lite 110" 2:35:1*DVDO Duo i/p scaler*Apple TV 1080p*MySky HDi*Cables-Wireworld Chroma 6 HDMI/QED Silver Anniversary XT/Chord Crimson plus/Clearer Audio Copper line mains*Control4 automation*
gel
gel's picture
Online
RE: Thor 3D won't play
Sorry to hear about your problems hope you get it sorted.  Can I ask how does it compare to your 91 Blu - ray player?  Many thanks.
__________________
Panasonic 50GT50, Pioneer Bdp-lx71, Pioneer Vsx-lx70, B&W FPM Series & B&W PV1.
KiwiMoto
KiwiMoto's picture
Well well.Damn player was factory set to USA in Country Code menu.Switched it in half a sec and...Thor in 3D Smile
If my player was set to wrong country code ex factory I bet this issue will pop up again....!
I'm pleased overall with the BDP 450 compared to the LX91.I don't really think there is much difference in SQ or PQ,and I must admit the 3D gimmick is probably more enjoyable than I thought it would be.
__________________
gel
gel's picture
Online
KiwiMoto wrote:
Well well.Damn player was factory set to USA in Country Code menu.Switched it in half a sec and...Thor in 3D Smile If my player was set to wrong country code ex factory I bet this issue will pop up again....! I'm pleased overall with the BDP 450 compared to the LX91.I don't really think there is much difference in SQ or PQ,and I must admit the 3D gimmick is probably more enjoyable than I thought it would be.
Hi, glad you got it sorted!  Thanks for that!  Perhaps another brief review of the 450 when you have had more time with it.  Many thanks.
__________________
