Sony S500ES picture quality.
I have a Sony S5000ES Bluray player.However the picture quality on Bluray discs is terrible,not as good as standard def.tv.I am using quality HDMI cabling.
What could be the problem?
Definitely some sort of problem there!
I use one myself, and find it's picture on a good Bluray is stunning - pin sharp. Have you set the output to 1080p? Which discs are you testing? There some iffy Blu's out there, so try anything from Pixar, or something like Tron. Which TV are you using? There are plenty of TV's out there that spoil Bluray's awesome picture quality.
Thanks for that.How do I check if the output is set at 1080?
All my separates are of the highest quality.Previously I was using a Denon Bluray Transport player and the picture was amazing.The Sony 5000ES is really bad!
Not familiar with the 500ES however as a Sony user have you checked all on the video outputs on the X Bar ensuring that 1080p 24f etc has been selected?
Can't believe it is not giving you a top notch picture...................?
Lounge: Sony 52W5500, Yamaha RX V2700, Sony S390 BDP, Sky+ HD 1TB, KEF R500/R600C/T301 rears, Chord Odyssey and Carnival for rears, Chord ProDac/HDMI, Chord Power Chords, BK Monolith DF
Family: Cambridge One, Rega P3-24 Elys 2, Mission 771e, Chord Carnival cable
Various: MacBook Pro, HP Pavilion dm4, iPod docks, iPhones, 160GB Classic and various generation Nanos
