Sony problem
10 replies [Last post]
KeithT
KeithT's picture
When I turn my blu ray player on this has just started to appeared on the TV screen, I've unplugged everything and it still appears;
"Ext memory in the EXT jack on the rear of the unit not recognised.  Check Ext memory, turn the power off, then turn on again."
There never has been anything in the Ext jack, whatever that is; Thoughts?
__________________
Townsend Rock/Excalibur/Ortofon 2M Black, Arcam AVR500, Roksan Kandy cd, Monitor Audio BX5
Clare Newsome
Clare Newsome's picture
RE: Sony problem
Sounds like it's got confused, and thinks there's a USB drive attached. Which player is it?
__________________
Group PR Manager - Computers Unlimited;
Former Group Editor of What Hi-Fi? Sound and Vision and Whathifi.com
Twitter: @ClareNewsome
Andrew Everard
Andrew Everard's picture
RE: Sony problem
Could be a faulty or misauthored Blu-ray disc has made the player think it has stacks of BD Live content to download, and the internal memory isn't sufficient, so it's searching for extra memory - many players have the option of adding extra memory via the USB port in this way.
A factory reset of the player may clear it, or you might want to try sticking a cheap USB thumb-drive into the USB port. A 2GB one should do it - you can pick them up for around a fiver these days.
It's all part of the 'joy' of Blu-ray and additional BD Live content and firmware upgrades being needed to play certain discs.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Clare Newsome
RE: Sony problem
Indeed. Just spent half hour having to firmware update and restart my Pioneer player so it could play new Blu-ray of The Magnificent Seven....
__________________
KeithT
KeithT's picture
RE: Sony problem
BDP-S363. Last disk that it played was Tinker, tailor without any problems and it's still in the draw. How do you reset it?
__________________
laserman16
laserman16's picture
RE: Sony problem
Should tell you in the user manual that came with it.
KeithT
KeithT's picture
RE: Sony problem
Ok I've gone through all the reset functions and I'm still getting the same message.
Next?
Return to Sony or buy a new player as it's probably as cheap as the repair!
__________________
bigboss
bigboss's picture
RE: Sony problem
Contact your dealer. If your player is less than 2 years old, they should repair it for free.
__________________
Clare Newsome
RE: Sony problem
Next?
Did you try Andrew's suggestion above re a USB drive?
__________________
KeithT
KeithT's picture
RE: Sony problem
Clare, er no I haven't; good reminder. Any usb stick work?
__________________
KeithT
KeithT's picture
RE: Sony problem
Ah! I've stuck my work usb in and reset it and it now plays blurays. As I need my work usb, time to buy a new cheap one!
Thanks all.
__________________
