Sony bluray bdp-s380 and bdp-s485 and HDD format type : FAT32 or exFAT
3 replies [Last post]
kweq
kweq's picture
Smile hello experts...
I really need urgent answer from u guys regarding the files type supported for the above sony bluray players I owned.
I have bought a 500gb external hard disk to store all of my movies inlcuding those with big size i.e. more than 4 gb for the majority of my 3D and 1080p movies collection. I read many forums regarding NTFS, FAT32 and exFAT. For info, i am using the latest macbook air to transfer movies and also sometime using my normal windows XP laptop. So, this is clear that NTFS is out of my option since it is not supported by mac (can read but cannot write)
Therefore, i need you advise regarding which is the best to format my HDD...FAT32 (limited to 4 gb files) or exFAT? More importantly, i need to make sure those movies can be played using the above blurays. Aybode tried playing using the exFat formatted HDD on those bluray? Does it work?
looking forward to hear from u guys soon.
AnotherJoe
AnotherJoe's picture
RE: Sony bluray bdp-s380 and bdp-s485
If you really need files > 4GB then I would suggest NTFS, and downloading a tool thats lets u use NTFS on your Mac .
NTFS mounter is freeware or something like Tuxera NTFS is £20
http://www.macupdate.com/app/mac/32571/ntfs-mounter
Anything else is going to be a compromise.
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
kweq
kweq's picture
Thanks but at the same time, I was hoping that somebody can prove exFAT does works on those BD Players
AnotherJoe
the specs say that it doesnt
__________________
