SONY-BDPS790-MR - Not playing 3D!!!!!!!!!!!
5 replies [Last post]
Frosts
Frosts's picture
We have an LG 42LW650T  (3D TV) and we connect through a Onkyo TX-SR608 AV receiver (3D capable). When we try to play 3D, it tells us that either our TV or player are not 3D - Hogwash! We can play the 3D movies without problem through our PS3, so why not our 3D Blu-Ray player?
Both the TV and Blu-ray player have the latest firmware updates.
audiowizard
audiowizard's picture
RE: SONY-BDPS790-MR - Not playing 3D!!!!!!!!!!!
That sounds very strange indeed. I have the same player, and have no issues with 3d playback. Try just connecting it directly to the tv, to eliminate any issues as its passing through your amp. But, like you said, if 3d is working via your amp using the ps3, I doubt its the amp. I will have a look it my blu ray player settings later to see if i can maybe help you. Could be a simple setting, or a disc problem?
__________________
Panasonic TXP50GT30, Sony BDP-S790, Sony STR-DH820, Q Acoustics 1010i 5.1
Frosts
Frosts's picture
All sorted thanks - turns out the Chroma 6 HDMI cable was a bit doggy, switch it for the same version connecting to my Sky Box, and issue resolved. Strangely, that dogggy cable works fine on the Sky box and allows 3D view via Sky.
All sorted thanks.............except now now the Sub (Boston XS) has stopped working (buying a cheap Sub Woofer cable), just to check that the cable is not the issue. Hope not, paid £26 for the Cord Crimson Plus.
Alantiggger
Alantiggger's picture
Glad to hear that it is now working for you   Smile  I bought one of them today and my high speed HDMI's are meant to be delivered tomorrow ... can't wait
woohoo!
__________________
Lounge :  Samsung PS51E6500, Sony BDP S790, Virgin media XL, Onkyo  TX-SR508,
Tannoy Arena 5.1 with stands.(http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-and-av-speakers/tannoy-arena-96472/review)
Bed : Panasonic PX70 and a Sony BDP-370 Blu ray Player.
So far  :)
OneBoxSystem
OneBoxSystem's picture
Doggy cables? Not heard of them....Smile
The_Lhc
The_Lhc's picture
Sky 3D doesn't require the same amount of bandwidth as Full HD 3D does.
__________________
No signature worth mentioning...
