10 posts / 0 new
Last post
Scissor_digits's picture
Last seen: 7 months 3 weeks ago
Sony BDP-S370 & Zero Dark Thirty blu-ray
Posting in this section but don't know if it's player or TV (Sony KDL-40EX603) Both are running latest software versions
When I try to play the Zero Dark Thirty blu-ray at precisely 2 minutes and 10 seconds into the film the TV switches off. Tried playing the blu-ray 5 times and same thing every time. The blu-ray itself is a rental from Blockbuster but I don't think it is the problem as it looks like a pretty new disk in very good condition which hasn't got any marks or scratches on the playing surface, I just don't have any other players in the house to test with.
I know the chances of someone out there with this TV/player combo also having tried to play the same blu-ray are slim but you never know. In the meantime I have emailed Sony support and if there's anyone out there with any pearls of wisdom please chip in
rs6mra's picture
Last seen: 3 months 6 days ago
RE: Sony BDP-S370 & Zero Dark Thirty blu-ray
Have you tried any other blu-rays after you encountered this problem?
macdiddy's picture
Last seen: 15 hours 25 min ago
Sounds like might be some form of over active copy protection kicking in, if you are saying it happens at the same point of the film each time.
I have never tried any rental discs myself so I may be wrong.
As always with this type of problem, have you checked all the menu settings on both your tv and blu-ray player.
If you really want to watch this film then you can pick up one on Amazon for under £10.
Hope this helps
Smile
All of my blu-rays play without any problem. I watched The Dark Knight straight afterwards.
macdidddy, sorry I'm not grasping your logic. I really did want to see the film which is why I've rented it from Blockbuster. Why would I want to buy the same blu-ray from Amazon with no guarantee it won't do exactly the same thing and then having to go through the hassle of trying to return it to Amazon?
macdiddy's picture
Sorry, I didn't mean to cause offensive with my suggestion.
Its just that I have never heard of, or have had this problem happen to me with all the discs I have brought through Amazon, HMV etc including my copy of Zero Dark Thirty.
What I meant was that sometimes there can be differences between rental copies and the final retail version hence my going down the copy protection route.
Once again sorry.
psurquhart's picture
Once again sorry.
I would not take any notice of this advice.
A rental copy or a retailer copy - won't make any difference - it is a film on a Blu Ray disc. The same film produced and manufactured the same way.
I had issues with my 370 on certain discs (mainly freezing) but I have never had a disc shut everything down before. Very strange !
Son_of_SJ's picture
Last seen: 1 week 6 days ago
Whre are the libel lawyers when you need one? I'm pretty certain that mcdiddy did NOT write the text above, despite its appearance within the quotation in psurquhart's post.
Parlour: Sony KDL-75W855C and 12.1 system; Kitchen: Panasonic TX-P65VT65 and 8.1 system; Front bedroom: LG 60PZ950T and 5.2 system; My bedroom: Pioneer LX5090 and 7.2 system. Retired, since Sat 13-Feb-2016, Pioneer 428XD!
Son_of_SJ's picture
Hello Scissor_digits, I have the Blu-Ray of Zero Dark Thirty, and I've played in in two different Blu-Ray players, with no problems.
Not too sure what happened their, libelous indeed however the advice is still correct !
OK, to steer this post back on track Sony support have ever so helpfully advised that it MUST be the blu-ray at fault here and not their TV or blu-ray player. In the midst of all this Blockbuster by post has ceased trading so I've now signed up with Lovefilm and will rent a copy of the blu-ray from them. I'll update this post when I've received it.
Log in to post comments
