Sony BDP 790 owners help needed
Sat, Feb 2 2013, 11:19AM
Had this about a month now and was going through the settings and in the audio settings there is an option called "downmix" and it says " Set whether to apply Dolby Surround to the output audio signal" you then have the choice of stereo or surround. I have an av receiver which delivers 5.1 surround sound which works fine. I currently have it set on stereo, I guessed the surround signal would be sorted by the amp so chose not to let the blu ray do it. Is that correct?
- Login to post comments
Absolutely correct. Your choice to experiment but usual advice is as u have it letting the receiver decode rather than player
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1Base trap Project - http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-pro... treatment - click for pics : Room pix - Clicky : Old setup - Clicky
