sony 360 software
Wed, Mar 28 2012, 10:16PM
Hi there, I'm in south africa and a friend of mine bought me a blu ray movie(avatar) from India but it won't play on my sony 360, I'm told there is a software I need to load from somewhere and download onto the player. Can anybody help? I'm reluctant to contact sony here in SA as I have found them to be clueless and uninterested. Would appreciate your assistance, many thanks
Assuming the region code is the same it should play the BD you have after you plug the BD Player into the internet & check for a firmware update, it should do it automatically.
Regards...
My System
Sony Bravia 46HX853 Calibrated Settings
