7 posts / 0 new
Last post
Stuart.W.D's picture
Last seen: 1 year 11 months ago
Recommend Sony - Panasonic: Blu ray- player
RE: Reccomend Sony - Panasonic: Blu ray- player
Panasonic DMP-BDT230 or Sony BDP-S5100 (Tough Pick)    :?
bigboss's picture
Last seen: 5 days 7 hours ago
Both are equally good. Sony has more "smart" features.
Would you point me more towards the Sony:BDPS5100B !?
skippy's picture
Last seen: 1 month 1 week ago
I have the Panasonic and find it very clunky.
If you are using it for movies, the picture is very good.
The smart stuff just isn't that smart...very glitchy
bigboss's picture
Totally depends on your requirements. If you're going to use it for BBC iPlayer, YouTube, Netflix, Lovefilm etc., Sony has more features than Panasonic. You can't go wrong with either otherwise.
mattmeer's picture
Last seen: 3 years 2 months ago
RE: Recommend Sony - Panasonic: Blu ray- player
Which bluray player supports mkv files at 24p framerate? Panasonic displays those files at 60hz I believe, not sure about the Sony. It doesn't happen with bluray discs
Log in to post comments
