11 posts / 0 new
Last post
Dipesh Jaga's picture
Last seen: 9 months 19 hours ago
PS4 or Sony BDP-S5200
English
Hi Guys
just wanted to know from a sound and video prospective will the PS4 be as good as the blu ray player
i watch alot from the harddrive and a bit of blu ray discs
cant decide which method i should go for
previously i had a ps3 which is now broken. So in the market?
bigboss's picture
Last seen: 4 hours 18 min ago
In my experience, there is no
In my experience, there is no difference in blu ray picture quality between different blu ray players, as long as no artificial processing is employed by the player. Just bear in mind that PS4 may emit fan noise (like the PS3).
Noise im okay with as the
Noise im okay with as the player is far from me.
iv been trying to find out if the PS4 plays Dolby TrueHD
Any idea if it does?
bigboss's picture
When using PS4, select Linear
When using PS4, select Linear PCM or LPCM which is bit by bit same as Dolby True HD. LPCM is the studio master which is exactly the same as, or superior to Dolby True HD.
Thanks,
Thanks,
do you think audio and video will be the same as a blu ray player
bigboss's picture
For blu ray picture and
For blu ray picture and bitstream audio, will be the same. DVD upscaling can be different.
lonely boy's picture
Last seen: 9 months 3 weeks ago
The PS4 reportedly had issues
The PS4 reportedly had trouble deinterlacing 1080i content and some DVD upscaling problems, I think these issues have been resolved now.
Glacialpath's picture
Last seen: 6 days 19 hours ago
hybridauth_facebook
hybridauth_facebook_100001088194979 wrote:
Hi Guys
Video wise there might not be much difference between the PS4 qand the dedicated sony BD player. Sound wise however if you have an AV reciever I would set the PS4 to output bitstream and let the AVR decode the audio as it will do a better job than the PS4. That is certainly the case with the PS3 anyway.
I have noticed quite a big difference between players piture wise. The pic from my LX71 is better/cleaner than the LX70 I also have. I have the chance to compare many players at old job. The cheaper ones were never quite as good.
Hi-Fi: Campridge audio D500 SE, DACMagic 1, C500, P500.. Monitor Audio BR1 speakers.
H-T: Pioneer; Kuro LX5090, BDP LX71, SC LX73. CA P500. SKY+HD. Rel Q50. Mordaunt Short Avant.
Hi all,
Hi all,
I went for the Sony Bluray player
it seems good easy to handle.
I got the Sony STR 1050 recevier and wanted to know if you can use one remote for both?
If Songpal app will work on this bluray player as i could not get it to work
screen mirroing etc works well
Thank you guys for the advice
hybridauth_facebook
Hi all,
Hi there. Yes because they are both Sony you should be able to use all th buttons that have the same function. To control the BD player via the AVR remote you may need to select BD then slelect Receiver again to go back to controling the AMP.
Some BD functions will only be accessable from the BD remote though.
Log in or register to post comments
