PS3 V Panasonic DMP-BDT210
Morning, i am thinking of putting my ps3 into the 'boys playroom' and buying a Blu-ray player for my lounge i have a reasonably good set up in my lounge and was wondering if i will notice any differences in picture and sound ?
Many thanks...
Hi Paul, At the moment i have my PS3 slim connected to my Onkyo TX-SR605, speakers are Front B&W 685s, Centre, Rears and Sub Kef 3005se and TV Panasonic TXP50ST30 if this helps
Cant really comment on the slim I'm afraid, not sure if its any better than the fat.
Impossible to say - some people can tell differences between Blu-ray players whereas others see and hear no differences at all. I'd suggest you take the PS3 slim to a dealer so you can run a comparison on the same screen / surround system.
Also, take some Blu-rays / DVDs with you that you know very well.
Oh ok thanks i really thought there would be a difference...
Worth noting that I didn't say there wouldn't be a difference, however, it does seem to be quite subjective as to whether people can see or hear differences or not e.g. I saw and / or heard differences between each of the Blu-ray players I auditioned when I purchased my Marantz, but others have stated they could not tell the difference between the PS3 and Denon's DVD-2500BT when they've compared them.
That's why you really need to go and audition it for yourself - no one else can tell you whether you'll see / hear a difference or not.
Cheers professorhat
Ive got a very similar set up same tv Onkyo 606 and Quad speakers. i up graded my fat PS3 for the Sony 370 and noticed the difference with blu-ray, but it fell short with dvd playback, audio was better, but now ive just the st30 and need a 3d player.I would consider the BDT310 with its two hdmi's.
Depends which PS3 you are using and what you are plugging it in to. I noticed an improvement in sound as I have a PS3 fat which cant bitstream. I have the BDT310 (same thing as yours with two hdmi ports) and have it bitstreaming to my Onkyo 805.
I noticed an improvement in motion handling over the PS3 as well, but wouldn't want to comment too much on image quality as my TV is hardly reference quality
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
