Please recommend a blue ray player for music
9 replies [Last post]
geordie777
geordie777's picture
Hi everyone
My technics cd player has just give up the ghost and I have also been looking to get a new blue ray player as I only have a cheap Asda one at the moment.  So to kill two birds with one stone as they say can you guys recommend a blueray player to do this. I assume I will be able to rig up my technics amp to the tv and play through a pair of MA BX2's.  Thank you for any advice. Budget is £300.
__________________
Rega RP1 Golding 2100 Cart. Marantz pm6004. Marantz cd6004. MA BX2s
professorhat
professorhat's picture
RE: Please recommend a blue ray player for music
I'd probably take a look at the Pioneer BDP-LX55 or this Marantz also looks like it's worth a demo.
In terms of connecting it up, you would be better off connecting the Blu-ray player directly to your technics amp (in the same way as your old CD player connected), rather than playing music via the TV.
John Duncan
John Duncan's picture
professorhat wrote:
this Marantz
Niiiice
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
eggontoast
eggontoast's picture
geordie777 wrote:
Hi everyone
Take a look at the Marantz ud5005, if you shop around you can get it under £300 now. It does 3D blu-ray, CD and SACD it also sounds excellent with music. You would be better off connecting the blu-ray played to your Technics amp via an analogue RCA lead for music and obviously via HDMI to your TV for movies.
__________________
Sonos > M-DAC, Beyerdynamic A1, FiiO E17/E9, HLLY DMK-IV, STAX Lambdas, Denon AH-D5000, Sennheiser HD-600, Beyerdynamic DT770, MCA customs - Magnum V4's, Sennheiser HD-265 linear, Sennheiser CX300-II.
Oldboy
Oldboy's picture
I would have to agree with Prof regarding the Marantz or pioneer options (i came close to getting the LX55 myself recently) but i would add that the Denon DBP 2012 would be worth considering too as music is important to you or even the Panasonic BDT500. If it was me i would be looking at either the Marantz or Denon options as both will give good results with music and connect it with analog interconnects for stereo music and HDMI for home cinema duties.
__________________
Sony KDL46HX853, Yamaha RX-A2020, Dali Zensor 5 5.1, Panasonic DMP-BDT500MR, Marantz CD6003, Marantz PM6004, Beresford TC-7220 MKII, PS3, Xbox 360, QED Silver Anniversary XT speaker cable, Wireworld Chroma 7 HDMIs, Chord Crimson Sub and RCA, Chord Superscreen Mains Cable
geordie777
Thanks guys I like the look of the Pioneer seems a really good piece of kit for the price although some of the reviews are a bit sketchy. The Marantz looks a good option to but does it play Flac files ? Just to add the technics amp is only a temp measure hoping to upgrade soon so any suggestions on what would be a good choice to go with the Pioneer or the  would be appreciated. By the way did consider the Denon but a bit out of my budget at mo. Budget for a new amp will again be about £300.
__________________
eggontoast
No that is one major oversight IMO, the Marantz doesn't play Flac files.
__________________
professorhat
geordie777 wrote:
Just to add the technics amp is only a temp measure hoping to upgrade soon so any suggestions on what would be a good choice to go with the Pioneer or the  would be appreciated  ... Budget for a new amp will again be about £300.
Are you looking at a stereo amp or an AV receiver?
geordie777
Sorry should have said  I will go for an AV reciever When I upgrade.
__________________
unfocused
unfocused's picture
I have the Marantz UD5005 and it sounds better with CD's and multi channel audio than the Arcam DV137 it replaced, and you can get it for around £300
