15 posts / 0 new
Last post
sameersuleman's picture
Last seen: 1 year 3 months ago
pioneer bdp 150
hi,
I have a pioneer bdp 150 player and am unable to play BDMV formats from my hdd.According to instruction manual they say that a folderf named AVCHD to be created and then played via the avchd file on the player. i have done this but the avchd folder on the hdd is not visible thru the player.
any solutions? please assist.
b/r
sameer
Tarxman's picture
Last seen: 2 years 10 months ago
RE: pioneer bdp 150
Has the hard drive been formatted to FAT32 prior to loading the files onto it? If it hasn't, I dare say that would be your problem.
RE: pioneer bdp 150
thanks for the reply.Please advise how i can check this and if its not FAT32 formatted,how can i go about doing it?please gude.
b/r
f1only's picture
Last seen: 2 days 6 hours ago
RE: pioneer bdp 150
Plug it in to a pc / laptop, then double click on my computer if you have it on the desktop, if not it is in the main list next to the programs.
Once there  right click on the icon of the drive that says Removable disk (UNLESS IT HAS BEEN RENAMED) & click on properties which will be at the bottom of the list.
 Then on the info screen under the General Tab it should say:
Type : Removable Disc   & then it should say either one of these two options directly underneath
 File System NTFS
or
 File System FAT32
Regards ..
A/V Pioneer SCLX59 Speakers B&W 683 S2 685 S2 HTM61 S2 Centre 686 S2 For Atmos x4 ASW610 Sub x2 TV Calibrated 4K Panasonic TX-50AX802B BDP Sony PS3 & PS4 Pro HDMI Monster ISF2000HD Virgin Tivo Netgear ReadyNas104 12TB
pioneer bdp 150
hi--i seem to be having bluray playback issues on my pioneer bluray. suddenly  while watching blurays the movies reach a certain stage and freeze or start getting stuck.This is the case even with brand new bluray discs soi rulled out scratches. What could the problem be and is there a solution? The player is hardly 2 yrs old.
Hope someone can help
Rgds,
SAMEER.
bigboss's picture
Last seen: 6 days 10 hours ago
Is the firmware up to date?
i will update that immediatly
i will update that immediatly....will this help and how.
thanks
i just ran the update and it
i just ran the update and it says ''firmware is latest version no need to update''.
Please assist.
bigboss's picture
thanks
That's the main difference when it comes to blu ray; the player needs firmware updates to ensure future discs can be played without any problem.
bigboss's picture
Please assist.
Pioneer players do tend to suffer from such issues.....the reason I didn't get them. Maybe yours is doing the same. Email Pioneer customer service, or speak to them. They may release a firmware update for you.
any other possibilities
any other possibilities/problems apart from firmware maybe
the player was bought off
the player was bought off amazon and i live in Nairobi Kenya. I checked pioneer website and they dont give any email address.Is it possible you can assit me on this in anyway to get update
bigboss's picture
Contact them, explaining your
Contact them, explaining your problem and also mention where you live. They should direct you to the right place, or maybe help with issuing a firmware update.
DTS HD AND DOLBY MASTER HD INDICATOR NOT COMING UP
Hi Again,
I have two problems this time:-
1. PIONEER BDP150 +ONKYO AV RECEIVER R590-Until just a few weeks ago everything was working ok.ie dolby masterhd and dts hd indicators working well...now they are not working.
2.On the same setup when i use the receiver remote, no display comes up on the TV whereas it was displaying until recently.
Could you please assist.
Thanks-SAMEER
pls assist
Log in to post comments
