3 posts / 0 new
Last post
Lee_m's picture
Last seen: 2 years 8 months ago
Panasonic DMP - BDT360
Hello,
I have just bought the BDT360 and while it's playing you can hear a high pitched whine that's noticeable (sounds like you have bad tinnitus!!) Is this normal or should I be returning it?! Always used by PS3 to play Blu-rays before and never had an issue.
Many Thanks
Lee
bigboss's picture
Last seen: 5 days 41 min ago
RE: Panasonic DMP - BDT360
Sounds faulty. Have you tried different discs?
Lee_m's picture
Yes, tried Thor 2 in 3D and then The Hobbit 2 (normal bluray) both made the noise Sad
Log in to post comments
