Panasonic DMP-BDT210
4 replies [Last post]
napule
napule's picture
Bought this yesterday from RS, took it home, set it up, put a disc in and was horrified to find the volume of noise coming from the machine, you can even hear it with the volume at a reasonable level.
Taking it back today, has anyone else had these issues, I can't believe that a £175 blu ray machine should do this?
Took me ages to change the remote code as I also have a panasonic DVD recorder and TV.
Any alternatives at that price range?
__________________
nads
nads's picture
Online
RE: Panasonic DMP-BDT210
sounds like a few have noise issues. (been comments on here about this) mine is fine. (310) exchange it.
__________________
Not a HiFi Nut. Just has a pile of Nads.
shoenils
shoenils's picture
Hi
Does Panasonic DMP-BDT210 support HDD(FAT/NTSC)? What about ONKYO BD-SP809?
sony bdp-s780 supports it. Any other newer 3D blu ray player which support HDD?
Thanks.
laserman16
laserman16's picture
Well according to the manual all 3 models ( 110,210,310 ) can support an HDD formatted to FAT32 via USB up to 2TB.
Playable files are DivX, MKV, MP3, and JPEG/MPO.
shoenils
shoenils's picture
Thanx.
Without NTFS support files >4GB becomes problem then.
