Panasonic dmp-bdt110 sound settings
Fri, May 4 2012, 3:57PM
I posted a topic regarding the correct settings for my Sony blu ray,when connected to my Yamaha amp so dd true hd is stated on the amp.
Thanks to your help,I'm now enjoying amazing sound and brilliant picture.
My friend has just purchased the pan dmp-bdt110 and was wondering what the correct soun settings should be on his,also any tips on the picture settings please,plus 3d settings
I should say he has the same amp as mine,and is connected vis hdmi .
Thank you
In Digital Audio Output set "Dolby D/Dolby D+/Dolby TrueHD" to bitstream, also the same for "DTS/DTS-HD" and "MPEG Audio".
Then set BD-Video Secondary Audio to "Off".
Sorry do not use it as a 3D player so I cannot help you on that bit.
