Panasonic 310.A good choice for a player with 2 HDMI outputs?
1 reply [Last post]
charles 126
charles 126's picture
My Onkyo 875 needs a separate feed for audio for 3d.The above player seems a good option or would the much more expensive Oppo or Cambridge be a better choice?I will be viewing on a 92" screen using a Panasonic AE5000 projector.
Thank you
Charles
markjaspi
markjaspi's picture
RE: Panasonic 310.A good choice for a player wit
For me the 310 is an excellent player, the picture and sound quality is excellent, but then again I'm only using it with a 50" screen. Better BR players tend to look better on bigger screens, especially when used with a projector. It will also depend on your speaker setup, as generally there is less difference across the board with the picture, but more difference with the sound quality. I think only you can judge whether the more expensive player is worth the extra outlay.
__________________
Panasonic 50GT30B | Marantz SR5006 | Boston Acoustics A26 front - A225C - A26 rear | Panasonic BDT310 | Sky+ 1TB HD | Virgin TiVo | iPad 2 | Samsung Galaxy SIII | New Apple TV | Control: Roomie via iPad & iPhone | Xbox360
