35 posts / 0 new
Last post
JASPER09's picture
Last seen: 3 years 3 weeks ago
Oppo or not
Hi guys, been out of the upgrade game for a while so my question is this; Would the new oppo BDP 103D represent an upgrade over my current player the Denon 2500BT?
michael hoy's picture
Last seen: 1 year 1 week ago
RE: Oppo or not
Hi and welcome.
I am not sure of the Darbee element of the OPPO (D), I had the 2500BT for a long time and now own the OPPO 95.
Depending on whether or not you want / need the extra features and of course the HD audio, picture quality wise the OPPO 95 is better but not night and day.
Personally I would change from a 2500BT to an OPPO again, but maybe save some money by not buying the 103D and get the 103.
Can you demo?
AV- Panasonic VT30¦Pioneer LX85¦MA Apex Speakers¦Antimode 8033S¦OPPO 95 BDP
Hi-Fi- Spendor A3¦Cyrus 8 XPD QX¦Quad 909 power amp
Music stored on Server running Windows Home Server.
gel
gel's picture
Last seen: 10 hours 58 min ago
RE: Oppo or not
michael hoy wrote:
Hi and welcome.
Can you demo?
Agreed, 103 is a good player.
Stop
strapped for cash's picture
Last seen: 4 months 2 weeks ago
RE: Oppo or not
Welcome to the forum.
It'd be really useful if you could let us know why you're upgrading your BDP, and give some indication of what other kit you own.
If you have a reasonably high end TV, I think you money would be better spent elsewhere. If you're simply looking for a 3D-ready player, a cheap Panasonic BDP will more than suffice. While there's some debate over whether more expensive BDPs offer better performance, any improvement would be negligible at best.
In my view, your money could be more effectively spent in one of two ways:
1. Professional calibration of your television. On a performance-per-pound basis, this is the best system upgrade available and will deliver substantially greater improvement than a new Blu-ray player
2. Upgrading other kit, such as your AVR or speakers.
Relative to the above two options, a new and quite expensive Blu-ray player becomes a false economy.
JASPER09's picture
Thanks for the warm welcome,
Thanks for the warm welcome, I was looking at AV cabinets for my kit because we have just moved into our new house and I'm planning a floating wall for our front room. Whilst searching i clicked on the Oppo ad on a website and had a read, sounds like a decent bit of kit but did'nt want to spend that much if I was'nt going to notice much difference in quality. Having been out of the loop for several years ( spending all my time and money on making and paying for babies!!) I just thought I'd pick some brains on here!
BIGBERNARDBRESSLAW's picture
Last seen: 8 months 2 days ago
RE: Oppo or not
I'm in agreement with Strapped For Cash, spending money on the right speakers, amps and tvs can make a big difference, blu ray players can't.
I have owned expensive and budget blu ray players, and I am yet to notice a difference between the picture or sound quality when watching a blu ray disc. I think expensive players can upscale DVDs to a higher standard, but again, it's not a night and day difference.
The build quality was better on my more expensive player, but is that enough reason to spend loads of money and a new blu ray player?
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
RE: Oppo or not
Looking at your kit list, your TV isn't 3D ready. I can therefore see no need to upgrade your BDP at present.
I used to own the 2500 and it's bomb-proof. You won't find better build quality on a new machine, or notice any worthwhile improvment in sound and picture performance.
The 2500's disc loading times are a little slow, though this never bothered me particularly. (I can wait that extra 20 seconds!) As long as you're not having difficulties playing some discs due to firmware, I think you should stick with what is a genuinely excellent player. Smile
JASPER09's picture
RE: Oppo or not
thanks for the replies, well i guess I'll keep my hard earned firmly in my pocket then. Do you think it's possible to get an older TV like mine calibrated? Might be worth giving that a whirl once everything is up and running, I have to say my kit still puts a big grin on my face when i crank up something like the TRANSFORMERS bluray, I was just thinking that with how quickly technology moves these days my big ol' player might be a bit of a dinosaur now!
RE: Oppo or not
Here's the calibration section of the HDTV Test review of your TV:
http://www.hdtvtest.co.uk/Pioneer-PDP-LX508D/Calibration/
Out of the box, the review sample performed very accurately, though televisions drift over time and yours will likely be less accurate now than when you bought it.
The 508D has less extensive calibration controls than many newer televisions, though calibration should improve the picture. Whether it's possible to achieve a reference performance, I don't know. You should be able to get close.
It's a borderline case in my view. I'd suggest this is a better investment than a new BDP. Whether it's worth it overall is a tough call. You'd lose nothing by chatting to a professional calibrator and getting their opinion.
RE: Oppo or not
To add to the above, the age of your TV is also a factor. It's now 6-7 years old, so you'll of course need to consider whether you'll get sufficient future use out of it to justify the cost of calibration. I'm not sure I'd throw down £200-300 in your case.
RE: Oppo or not
Your tv was exactly the same model as I had, and it's on record here, that I bitterly regret selling it.
I found some great settings for my LX508D on the net, which I used, but I'm struggling to find them now.
I'll post them here if I can locate them.
RE: Oppo or not
8 G D65 HDMI Settings.txt
I'm pretty sure these are the settings I used, hopefully the link will work.
JASPER09's picture
RE: Oppo or not
Ok, so basically stick with what I've got for now until my TV goes bang, I haven't got a problem with that at all. Let's pretend that my kit is your kit, what would you be looking to upgrade and with what?......just a bit of fun!
RE: Oppo or not
You could maybe add a PS4.
Otherwise, I think you're in pretty good shape.
Is there a part of your system you feel is lacking in some way?
JASPER09's picture
RE: Oppo or not
No not really lacking, just looking for ways to improve upon what I have. I was looking at BLOK cabinets when I saw the Oppo advert, are you happy with yours and is there a noticeable improvement in performance or do they just look lovely?! Will probably be getting one of the new consoles later in the year, not sure which one though.
professorhat's picture
Last seen: 1 month 2 days ago
RE: Oppo or not
Have a look at the exclusive games that are coming out and base your decision around that - there's not a lot between them otherwise. Make sure to check the Indie titles coming to the PS4 as I think a number of them will actually blow away a lot of the "mainstream" releases for outright fun, and for a fraction of the price as well. Resogun is a good example of that.
The owls are not what they seem...
Pages
Log in to post comments
