14 posts / 0 new
Last post
wawr's picture
Last seen: 2 years 2 days ago
oppo BDP 103D
Hi all.
Just about to start up- dating all my home cinema kit, we are moving to a new house in July and will be converting the garage to the dedicated cinema room.
I have chosen my amp - Anthem MRX710 and the projector Sony HW55ES  now however its time to think about the blu-ray player, it must be 3D. I am at the moment drawn to the OPPO 103D, £600 is about my limit at the moment as i know within about 12 / 18 months I will probably be looking to up grade this again.
So before fully committing to this player I was wondering if anyone has any other ideas / views as to another player I could demo ??
Thank 's in advance for your views
bigboss's picture
Last seen: 6 hours 28 min ago
RE: oppo BDP 103D
With regards to your projector, have you considered this? Similar performance as the HW55 at a bargain price:
http://www.avforums.com/review/sony-vpl-hw40es-hw40-sxrd-3d-projector-review.10331
Do you definitely want the Darbee edition Oppo? Opinions are split about the artificial processing of Darbee. I would suggest you demo it before purchase. If you're not going to use the Darbee processing, Oppo 103 is equally good. You can't go wrong with the Oppo.
wawr's picture
RE: oppo BDP 103D
bigboss wrote:
With regards to your projector, have you considered this? Similar performance as the HW55 at a bargain price: http://www.avforums.com/review/sony-vpl-hw40es-hw40-sxrd-3d-projector-review.10331 Do you definitely want the Darbee edition Oppo? Opinions are split about the artificial processing of Darbee. I would suggest you demo it before purchase. If you're not going to use the Darbee processing, Oppo 103 is equally good. You can't go wrong with the Oppo.
thank you for your reply, Yes your right I will deff give the new sony HW40ES a demo, but i thought for almost half the price of the 55ES there must be some compromise in quallity somewhere ?? - BUT  a demo is definitely a must before i buy.
Same goes for the OPPO 103 with and with out the darbee processing !!
bigboss's picture
RE: oppo BDP 103D
The only difference between the HHW40 and HW55 is lack of dynamic iris in the former (which is artificial processing, and most people usually keep it turned off anyway) and 3D glasses are not included (you can buy them separately). Everything else is exactly the same. A demo will help you decide.
wawr's picture
RE: oppo BDP 103D
Wow thats great to know BIG thank you - looking like it will be the HHW40 then !!
wawr's picture
RE: oppo BDP 103D
You seem no know quite a lot about home cinema, can i please ask your opinion about the components im putting together,
sony projector (HHW40 OR 55ES)
Anthem mrx710
Oppo 103 or 103d
Grandview 7foot fixed frame screen
B&W 600 series speakers 7.2
I will by end of the year changing my speakers to the Keff Q series again it will be 7.1 or 7.2 ?? Kef Q900 front Q600 centre etc ....
your opinion will be  greatfull
Many thanks !!
bigboss's picture
RE: oppo BDP 103D
Your setup looks very nice, (no idea about the screen though). If the room is relatively bright, consider Draper ReAct 2.1 screen.
For speakers, if you're saving £1000 on your projector by going for HW40, why not consider something like Kef R series or Monitor Audio 6AV12?
themovierooms's picture
Last seen: 1 year 7 months ago
RE: oppo BDP 103D
If you are planning to get the projector professionally calibrated you would be better with the HW55. The iris is not only Auto but has the ability to be set to manual enabling finer tolerances on the calibration. Side by side there is a big difference but only if calibrated. You also may struggle to find the Oppo 103/5EU as officially it has been discontinued and replaced but the 103/5D. As always though as advised, get a demo.
bigboss's picture
RE: oppo BDP 103D
Officially discontinued? I can still see the models on their website:
http://www.oppodigital.co.uk
simonlewis's picture
Last seen: 5 hours 20 min ago
RE: oppo BDP 103D
The 103D is on their website not the 103, which i presume has been discontinued...   :?
jacobmorrison's picture
Last seen: 3 months 3 weeks ago
RE: oppo BDP 103D RE: oppo BDP 103D
It's not one of the highlighted players but the complete product list is at the bottom giving a link to:
http://www.oppodigital.co.uk/ecommerce/product/BDP-103EU.aspx
Pro-ject 2Xperience Acrylic-Speedbox ii-Ortofon MC Quintet Bronze, Leema Pulse, Sonos Connect-Musical Fidelity VDAC II-Custom HiFi Cables DC1, Monitor Audio Radius 270
Mtenga's picture
Last seen: 3 months 4 days ago
Yes the 103eu is discontinue now in favour of the darbee edition. There are still a few around at places such as Peter Tyson but not many. The darbee is worth the extra 100 quid anyway for novelty if nothing else.
the 710 is a great amp and the improvement over my previous yamaha 2020 is obvious. However the Oppo 103d does not do a bluray picture any better than my 50 quid panasonic in the bedroom. So no great shakes on that despite the hype. But the build and features like darbee and multiple channel out might make it worth the money to some.
RE: oppo BDP 103D
Yes, it finished some time ago. As mentioned some of the larger shops may still be holding stock but I would hazard a guess that there won’t be many left.
RE: oppo BDP 103D
Oddly, in the greatest comeback since Lazarus. Oppo emailed me a couple of days ago to say they have some 103EU's on the water. Should be available in 2-3 weeks.
Log in to post comments
