9 posts / 0 new
Last post
Sirguy969's picture
Last seen: 3 years 6 months ago
OPPO 105 connections to Denon AVR4308a
Morning All,
I will imminently be replacing my Denon 2500BT with the OPPO105.  I notice that my amp has the prerequisite terminals for making use of the excellent DAC in the OPPO.  Do I need "special" cables for this or will the bog standard red & white RCA leads do?  Is there any benefit from getting better cables?
Following excellent advice from the guys over on the computery type thingy forum I am now the proud owner of an Apple TV3, which is most excellent!  Should I wire this through the OPPO too?
Many thanks.
Cam.
GSB
GSB's picture
Last seen: 5 months 2 weeks ago
RE: OPPO 105 connections to Denon AVR4308a
I have five pairs of qed analogues from my oppo into my avr/intergrated.
I would say that the apple tv would connect to the port at the back for using the 105 as a dac,you need a usb A(male)+B(male)cable.
Sirguy969's picture
Thanks GSB. Do you notice a dsitinct improvement in the QED leads compared to the std red &white cables?  How much were they?
GSB
GSB's picture
Iv'e never done a comparason.They came with the oppo,they are from the qed performance range,so nothing mega expensive.
abacus's picture
Last seen: 2 days 4 hours ago
Red & White are purely for identification nothing more. (They do not indicate a standard of cable)
Unless you are using long runs, then so long as the cables are of decent quality (Not flimsy or cheap plugs) then there will be no difference in the sound, so don’t waste money on expensive cables.
Hope this helps
Bill
michael hoy's picture
Last seen: 11 months 1 week ago
Mark Grant have a decent offering of cables for stereo and multichannel connections see here
GSB, it sounds like you are saying the QED cables came with the OPPO, is this correct..
AV- Panasonic VT30¦Pioneer LX85¦MA Apex Speakers¦Antimode 8033S¦OPPO 95 BDP
Hi-Fi- Spendor A3¦Cyrus 8 XPD QX¦Quad 909 power amp
Music stored on Server running Windows Home Server.
GSB
GSB's picture
Kind of,David included them in the package i was buying(oppo+3x kef speakers),plus a decent discount Smile
Good deal then Smile
GSB
GSB's picture
Yep,after initial email i phoned the store and he agreed to make the 5 hour round trip worth my while :grin:
I would recommend hifix to anyone Smile
Log in to post comments
