NOT GETTING DOLBY TRUE HD LITE ON ONKYO HT-R590 RECEIVER.
35 replies [Last post]
sameersuleman
sameersuleman's picture
Hi All,
Would appreciate if someone can help.
I am using a sony bdp s370 player connected via hdmi cable to onkyp ht-r590 receiver. When i play a bluray dvd with dolby true hd i just get PCM displayed on my receiver.When i check the display it says doly digital 5.1 surround.
My audio settings :-
1. audio hdmi - auto
2.dsd output - off
3.bd audio mix - off
4.dolby digital - dolby digital
5. dts - dts
6.neo 6 - cinema
7.audio drc - auto
8.down mix - surround.
Please help.If possible please also let me know on what settings i should have on the onkyo receiver.
Rgds,
SAMEER.
GSB
GSB's picture
RE: NOT GETTING DOLBY TRUE HD LITE ON ONKYO HT-R590 RECEIVER.
I just play with stuff,more often I stumble on the correct settings,but sometimes I need advice too.
From what I gather you should not be using neo 6 which is a surround type decoder,you need to set your avr to a straight setting to except the HD.hope this helps.
__________________
PanasonicTX-P46GT30B..Yamaha RX-A1010...Music Fidelity M3i...OPPO105EU...KEFR100/R200C/3001SE/HTB2SE...SkyHD2TB...QED Copper Speaker Cable /HDMI/Analogue...PS3...IPAD2
f1only
f1only's picture
Try this, these are the settings on my Sony S380 & i get HD sound. Regards..
2.dsd output - off
3.bd audio mix - ON
5. dts - dts
6.neo 6 - cinema
7.audio drc - auto
8.down mix - Stereo
sameersuleman
Hi GSB,
Many Thanks for your quick reply.Really appreciated. I will try with the neo setting off and post result .
Rgds......
sameersuleman
Many Thanks F1,
i WILL SURELY TRY ALL THESE AND LET YOU KNOW OVER THE WEEKEND.
Rgds,
SAMEER
f1only
f1only's picture
Np. Double check your AVR settings if all of the above dont work.
RobinKidderminster
RobinKidderminster's picture
Online
AVR receiver must not be on dolby. Straight or pure or whatever / min 0rocessinf.
audio/auto, dsd/on if u use sacd discs, bd mix/off, dd&dts/downmix PCM, neo6/off, downmix/off.
Took me a while to get these right
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
atkins4725
atkins4725's picture
Hi, shouldn't the player be set to bitstream???? That way, the source is doing the decoding? Feel free to educate me if this incorrect :-)
__________________
Philips 56PFL9954H, Sky HD, Marantz SR 7005, CA 751bd, Monitor audio Apex, Chord Prodac, Chord active HDMI's, Chord chorus 2, Chord odyssey 2, Atacama equinox rack.
bigboss
bigboss's picture
Online
You're correct. If your blu ray player decodes audio, there's no way your AVR will know if it's DTS HD etc. although you will still get HD sound.
__________________
sameersuleman
hi all,
i tried all the above diffrent settings but am afraid still not getting the dolby true hd lite on the receiver.I also just tried a blueray with DTS HD MASTER AUDIO this also dosent seem to get the dts hd lite ON.When i display on the Receiver i am getting PCM SIGNAL saying 7.1 /or 5.1 multichannel. And yes my HDMI setting on receiver is DIRECT.
Oh God could some one come to my assistance am really now getting frustrated.
Thx in Ad,
SAMEER.
Alantiggger
Alantiggger's picture
sameersuleman wrote:
hi all,
Might as well swear....
Thx in Ad,
SAMEER.
__________________
Lounge :  Samsung PS51E6500, Sony BDP S790, Virgin media XL, Onkyo  TX-SR508,
Tannoy Arena 5.1 with stands.(http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-and-av-speakers/tannoy-arena-96472/review)
Bed : Panasonic PX70 and a Sony BDP-370 Blu ray Player.
So far  :)
AnotherJoe
AnotherJoe's picture
(I remember this problem on my Sony AV)
Make sure that your receiver has not got a setting for hdmi set as tv+receiver. It needs to be set to just receiver.
Otherwise the receiver will set to the lowest common denominator between the tv and receiver - ie PCM
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
jeff1967
jeff1967's picture
Hi
My audio settings on the Sony S370 are:-
2.dsd output - off
5. dts - dts
6.neo 6 - off
7.audio drc - wide
my sony amp is set to hdmi input and dolby true hd and dts hd light up.
regards,
jeff.
__________________
SONY 40EX503 TV, SONY STR-DG820 AMP, SONY BDP-S370, Sony SS-MF450H FRONT SPEAKERS, SS-CN550H CENTRE, SS-B1000 SURROUND L/R AND BACK, VIRGIN MEDIA TIVO, SONY VAIO LAPTOP USED AS DLNA MUSIC SERVER.
RobinKidderminster
Online
Mine :
Different to jeff ! Not sure which is right but experiment and let us (both) know !
hope one of us can help
ps flicking thru manual and p29 /30 not sure the amp actually displays truehd on front panel?????
__________________
sameersuleman
jeff,
just tried your settings....No didnt work,i am still getting only pcm signal.The difference btw your setup and mine is the avr,mine is onkyo HT-R590. I also upgraded the blueray firmware.
sameersuleman
Robin,
Just tried your settings also. No Bro..still not working for me. About the hd lite you asked, yes the fron panel had the lites and are supposed to lite up as soon as the signal is picked.
I didnt understand when you said reciever should not be on dolby-where are these settings? also my sony player dosent have an off option in down mix...we only have stereo and surround.
